2021 classing sheet?
Any idea when the 2021 classing sheets will be available?
Graham Cranston
#76 T50 | 2013/15 FT86
Re: 2021 classing sheet?
Yeah, I'm tryna decide between NAWZ vs. 2-stroke conversion for the FA20...
Good Morning
We're working on it. The rule book edits have been essentially completed, and the excel sheet is being done now. Some complicated math going on for this year so we're a little behind. Hope to have it done in the next couple of weeks.
Yes, everyone needs to do a new sheet every year, on that year's sheet.
Yes, your points are going to change this year, due to adjustments in multiple areas. Most cars will remain in their current classes, but some may be pushed, or find it to their advantage to move, into another class.
Thanks for the update. Still trying to figure out what tires to run.
Graham Cranston
I'm sure if it were finished it'd be posted, but I'll ask anyway. Is it done yet?
Spring mod season is here and I have a whole new class to figure out!
Dan Durusky
Mazda RX8
Mazda RX8
Thanks for the new classing sheets! Not as many thanks for the extra base points
Yeh, I got like five shiny new points in the off season... T70 here I come!
Dan Durusky
Mazda RX8
Mazda RX8
On the topic of classing sheets, has moving the calculator from Excel to Google Sheets been considered? This would remove the requirement of having Excel in order to fill out the classing sheets. It could simple be a read-only sharable link. A user would open it and Save-As to create their own. Easy peasy and free for all.
Currently, you can open the Excel sheet in Google Sheets, but there are some warnings about missing features and reduced functionality. I'm not sure if this is impacts our spreadsheet or not. If it were native Google Sheets you could also pretty it up a bit and use check boxes, etc instead of the drop down menus, etc.
I can help migrate it if need be.
Dan Durusky
Mazda RX8
Mazda RX8
Dan
I’m a dinosaur. Grew up on excel. Google sheets gives me a headache, and reminds me of Microsoft “Works” for you old farts- like excel but missing the really good functions. I will kick the can to the next Chief Steward to move the whole thing to sheets.
You could try LibreOffice, which is a free open source alternative to MS Office.
https://www.libreoffice.org/
I haven't tried editing the classing sheets with it, but it should work. You'll probably just have to loosen the default security settings to allow the Excel macros to run.
Some of the drop downs didn't work well when I had tried. I think google docs is a better option here, but be careful, I saw it miss some pts on some things.Mick wrote: ↑Wed Jun 16, 2021 7:40 amYou could try LibreOffice, which is a free open source alternative to MS Office.
Brandon Ganem
#105 Mazda RX8
#105 Mazda RX8
I'm no help here, but I wanted to point out that the current excel file does not work when I open it with my Excel app on an Ipad. I think it is the macros but not sure. If we are going to try to make any changes that would also be nice so a Laptop would not be required to view/edit the sheet.
