2021 classing sheet?
gcranston
Post by gcranston » Fri Feb 26, 2021 10:33 am
Any idea when the 2021 classing sheets will be available?
Graham Cranston
#76 T50 | 2013/15 FT86
Re: 2021 classing sheet?
Post by DanB » Sat Feb 27, 2021 12:18 pm
Yeah, I'm tryna decide between NAWZ vs. 2-stroke conversion for the FA20...
Post by dtlemoine » Sat Feb 27, 2021 9:19 pm
Post by dinoracer » Sun Feb 28, 2021 8:02 am
Good Morning
We're working on it. The rule book edits have been essentially completed, and the excel sheet is being done now. Some complicated math going on for this year so we're a little behind. Hope to have it done in the next couple of weeks.
Yes, everyone needs to do a new sheet every year, on that year's sheet.
Yes, your points are going to change this year, due to adjustments in multiple areas. Most cars will remain in their current classes, but some may be pushed, or find it to their advantage to move, into another class.
gcranston
Post by gcranston » Mon Mar 01, 2021 10:43 pm
Thanks for the update. Still trying to figure out what tires to run.
Graham Cranston
TXBDan
Post by TXBDan » Sat Mar 13, 2021 12:52 pm
I'm sure if it were finished it'd be posted, but I'll ask anyway. Is it done yet? :o
Spring mod season is here and I have a whole new class to figure out!
Dan Durusky
Mazda RX8
Boondocker850
Post by Boondocker850 » Tue Mar 16, 2021 7:26 pm
Yes! Thanks for all the hard work!
Andrew LaValley #1144 2007 Honda S2000
SandyClam
Post by SandyClam » Fri Mar 19, 2021 9:35 am
Thanks for the new classing sheets! Not as many thanks for the extra base points :|
Post by paultg » Thu Mar 25, 2021 9:55 pm
TXBDan
Post by TXBDan » Tue Mar 30, 2021 12:36 pm
Yeh, I got like five shiny new points in the off season... T70 here I come! 8)
Dan Durusky
Mazda RX8
TXBDan
Post by TXBDan » Mon Jun 14, 2021 12:54 pm
On the topic of classing sheets, has moving the calculator from Excel to Google Sheets been considered? This would remove the requirement of having Excel in order to fill out the classing sheets. It could simple be a read-only sharable link. A user would open it and Save-As to create their own. Easy peasy and free for all.
Currently, you can open the Excel sheet in Google Sheets, but there are some warnings about missing features and reduced functionality. I'm not sure if this is impacts our spreadsheet or not. If it were native Google Sheets you could also pretty it up a bit and use check boxes, etc instead of the drop down menus, etc.
I can help migrate it if need be.
Dan Durusky
Mazda RX8
Post by dinoracer » Tue Jun 15, 2021 2:20 pm
Dan
I’m a dinosaur. Grew up on excel. Google sheets gives me a headache, and reminds me of Microsoft “Works” for you old farts- like excel but missing the really good functions. I will kick the can to the next Chief Steward to move the whole thing to sheets.
Post by Mick » Wed Jun 16, 2021 7:40 am
You could try LibreOffice, which is a free open source alternative to MS Office.
https://www.libreoffice.org/
I haven't tried editing the classing sheets with it, but it should work. You'll probably just have to loosen the default security settings to allow the Excel macros to run.
beatus
Post by beatus » Wed Jun 16, 2021 9:50 pm
Some of the drop downs didn't work well when I had tried. I think google docs is a better option here, but be careful, I saw it miss some pts on some things.
Brandon Ganem
#105 Mazda RX8
Post by paultg » Mon Jun 21, 2021 6:08 pm
I'm no help here, but I wanted to point out that the current excel file does not work when I open it with my Excel app on an Ipad. I think it is the macros but not sure. If we are going to try to make any changes that would also be nice so a Laptop would not be required to view/edit the sheet.
