Thanks Scott!
Yeah I know. Had I not seen the video that my wife took of the lap, I never would have believed it myself!! I was shocked to see that kind of time on the lap timer....like I said I wouldn't have believed it if my wife hadn't gotten it on video. I was looking last night to see what it will cost to rebuild that sucker, and it looks like it is going to be quite lot. With the baby on the way in a couple of weeks, unfortunately it won't be my highest priority. I was really looking forward to going to Mt. Temblant this year. O well... we'll see what happens once I rip it apart and see how much damage there really is. But my gut feeling is that it is in sad shape. Before I realized what was wrong with it, I bought a new battery and tried to start it. There was so much drag in the engine, that the new battery could barely turn the engine over! WAAAAAAA!!
Joel Adams
1995 Pontiac Trans Am
Class T80
Class T80
TTA89
Joel,
Might want to make a post over here and if anyone local has something if you want to get up and running quick with less headaches.
http://www.ls1tech.com/forums/forumdisp ... 8922f&f=56
I used to have a 98 LS1 T/A and still keep in touch with some of these guys. There is always LT1 stuff floating around. I'd just buy a stock motor and throw it in there and go beat the crap out of it again.
Building motors is nothing but a headache that more times than not doesn't work out the first... or second.... time.
Thanks
I will check out that site to see what I can find. I know what you mean, I went through this last winter, and I am not looking forward to doing the work again. It is tedious and painful, and requires lots of time that I don't have right now!!! Thanks again, I will see what I find out there.
Joel Adams
Class T80
Class T80
I am going to check some of that easy stuff when I get home tonight. I was just too frustrated last night to go much further. I would assume that if it was something like that, that the engine would stay running, and it would tear the accesory belt apart. But who knows, I will check it out tonight.
Joel Adams
Class T80
Class T80
It has been confirmed....
I pulled it apart tonight after work. My problem is definately bad! The oil looked like a metalic swirl paint job, and had much metal in it. I attempted to pull the pan down, but ran out of light. I should have it down tomorrow. I need to lift the engine out a bit to get the pan out. So far it doesn't look too good.
Joel Adams
Class T80
Class T80
It was a stock bottom end with a built up top end. Apparently the stock bottom end could not keep up with the top end! Well I guess I will have to build it back bigger and badder now! Unfortunately it won't happen over night. I think I will upgrade it to a 383 stroker now. We'll see what my wife says about that!
Joel Adams
Class T80
Class T80
TTA89
Tentative plans for the car to have a Rollbar installed starting May 9th which is a day after we get back from Summit Point with SVTOA. I'm having the same guy that put the Rollbar in Brian Stonkus's Roush do a Duplicate Rear Rollbar for mine.TTA89 wrote:Yeah I'm gonna start seriously looking into a Bar and some harnesses.offcamber09 wrote:Mike you can expect 145+ mph at Mosport in your car in it's "de-tuned" state...extra underwear is not optionalDon P wrote:Mick's got it right -- bring extra underwear
Ordering Drivers Suit, harnesses, and SPA Magnets this week.
Good to hear! :thumbright:TTA89 wrote:Tentative plans for the car to have a Rollbar installed starting May 9th which is a day after we get back from Summit Point with SVTOA. I'm having the same guy that put the Rollbar in Brian Stonkus's Roush do a Duplicate Rear Rollbar for mine.
Ordering Drivers Suit, harnesses, and SPA Magnets this week.Should be good to go for Mosport in June.
