Thanks Scott!
Post by offcamber09 » Tue Apr 11, 2006 8:09 am
Did you say 1:15.5 ? Holy S..t ! That would have bettered Reed's record and is 4 seconds better than what you did last year with COM. You need to try to duplicate that motor again.
jadams
Post by jadams » Tue Apr 11, 2006 9:15 am
Yeah I know. Had I not seen the video that my wife took of the lap, I never would have believed it myself!! I was shocked to see that kind of time on the lap timer....like I said I wouldn't have believed it if my wife hadn't gotten it on video. I was looking last night to see what it will cost to rebuild that sucker, and it looks like it is going to be quite lot. With the baby on the way in a couple of weeks, unfortunately it won't be my highest priority. I was really looking forward to going to Mt. Temblant this year. O well... we'll see what happens once I rip it apart and see how much damage there really is. But my gut feeling is that it is in sad shape. Before I realized what was wrong with it, I bought a new battery and tried to start it. There was so much drag in the engine, that the new battery could barely turn the engine over! WAAAAAAA!! :(
Joel Adams
1995 Pontiac Trans Am
Class T80
TTA89
Post by TTA89 » Tue Apr 11, 2006 9:45 am
Joel,
Might want to make a post over here and if anyone local has something if you want to get up and running quick with less headaches.
http://www.ls1tech.com/forums/forumdisp ... 8922f&f=56
I used to have a 98 LS1 T/A and still keep in touch with some of these guys. There is always LT1 stuff floating around. I'd just buy a stock motor and throw it in there and go beat the crap out of it again. 8) Building motors is nothing but a headache that more times than not doesn't work out the first... or second.... time.
jadams
Thanks
Post by jadams » Tue Apr 11, 2006 10:11 am
I will check out that site to see what I can find. I know what you mean, I went through this last winter, and I am not looking forward to doing the work again. It is tedious and painful, and requires lots of time that I don't have right now!!! Thanks again, I will see what I find out there.
Joel Adams
Class T80
TTA89
Post by TTA89 » Tue Apr 11, 2006 10:24 am
I would just make a post that your looking for a stock LT1 motor. Good Luck!
Post by jlwhorf » Tue Apr 11, 2006 2:21 pm
Joel
It doesn't even turn over very well. In fact, it is making a horrendous squeaking sound
Did you make sure that your altenator or an other accessary did not seize? If you try to crank your engine with one of these siezed, it will make a horrendous squeak.
Jonathan
900 Monte Carlo PA
jadams
Post by jadams » Tue Apr 11, 2006 2:24 pm
I am going to check some of that easy stuff when I get home tonight. I was just too frustrated last night to go much further. I would assume that if it was something like that, that the engine would stay running, and it would tear the accesory belt apart. But who knows, I will check it out tonight.
Joel Adams
Class T80
jadams
It has been confirmed....
Post by jadams » Tue Apr 11, 2006 10:08 pm
I pulled it apart tonight after work. My problem is definately bad! The oil looked like a metalic swirl paint job, and had much metal in it. I attempted to pull the pan down, but ran out of light. I should have it down tomorrow. I need to lift the engine out a bit to get the pan out. So far it doesn't look too good. :cry:
Joel Adams
Class T80
TTA89
Post by TTA89 » Tue Apr 11, 2006 10:59 pm
Doesn't sound good Joel :(
Is this a rebuild or factory motor?
jadams
Post by jadams » Tue Apr 11, 2006 11:33 pm
It was a stock bottom end with a built up top end. Apparently the stock bottom end could not keep up with the top end! Well I guess I will have to build it back bigger and badder now! Unfortunately it won't happen over night. I think I will upgrade it to a 383 stroker now. We'll see what my wife says about that!
Joel Adams
Class T80
Post by offcamber09 » Wed Apr 12, 2006 9:54 am
jadams wrote:I think I will upgrade it to a 383 stroker now. We'll see what my wife says about that!
WAAAAAAA!!
After the baby, it's time to get her behind the wheel...that's how I justified the $150 brake pads instead of the brand name diapers :roll:
Post by jlwhorf » Wed Apr 12, 2006 10:48 am
If you are going to upgrade, might as well stuff in an LS7 :)
Jonathan
900 Monte Carlo PA
TTA89
Post by TTA89 » Wed Apr 12, 2006 2:28 pm
TTA89 wrote:
offcamber09 wrote:
Don P wrote:Mick's got it right -- bring extra underwear
Mike you can expect 145+ mph at Mosport in your car in it's "de-tuned" state...extra underwear is not optional :roll:
Yeah I'm gonna start seriously looking into a Bar and some harnesses.
Tentative plans for the car to have a Rollbar installed starting May 9th which is a day after we get back from Summit Point with SVTOA. I'm having the same guy that put the Rollbar in Brian Stonkus's Roush do a Duplicate Rear Rollbar for mine.
Ordering Drivers Suit, harnesses, and SPA Magnets this week. 8) Should be good to go for Mosport in June.
Post by Mick » Wed Apr 12, 2006 2:31 pm
TTA89 wrote:Tentative plans for the car to have a Rollbar installed starting May 9th which is a day after we get back from Summit Point with SVTOA. I'm having the same guy that put the Rollbar in Brian Stonkus's Roush do a Duplicate Rear Rollbar for mine.
Good to hear! :thumbright: :D
Post by Mick » Wed Apr 12, 2006 2:32 pm
