Rules changes to be discussed at BOD this week
Re: Rules changes to be discussed at BOD this week
Post by paultg » Sun Dec 19, 2010 11:12 am
When should we expect the results of this months meeting to be available? I can only imagine everyone is very busy with holiday stuff, our association didn't hold a December meeting and communicated via email.
Post by jlwhorf » Mon Dec 20, 2010 9:53 am
The highlight of the night was that point scoring rule passed. It basically says: Any competitor that completes more than 6 time trials, will have the lowest point event dropped. Any competitor that completes 6 or less, will be scored on thier total.
Others include: 99-05 miatas stay in SSB. In ST; wheel spacers of up to 1/4 inch are legal, aftermarket pressure plate and disc can be used (with limitations) but flywheel must remain stock, and mechanically adjusted fuel regulator NOT legal. Aftermarket seat definition and dot tire wordings (in SS, ST and SP) have be deffered until next meeting.
naschmitz
Post by naschmitz » Tue Dec 21, 2010 10:18 am
jlwhorf wrote:The highlight of the night was that point scoring rule passed. It basically says: Any competitor that completes more than 6 time trials, will have the lowest point event dropped. Any competitor that completes 6 or less, will be scored on their total.
Does this imply we have a 7 event season or does it apply to 8 event seasons too? If so, in an 8-event season could you carry points from 7 events if you attended all 8?
Bert Schmitz
nateh
Post by nateh » Tue Dec 21, 2010 10:26 am
"If more than 6 points-scoring events occur in the series, the lowest scoring event for each competitor will be dropped from the points totals for that competitor A missed event yields zero points, and therefore becomes the dropped event."
Post by WillM » Wed Dec 22, 2010 11:33 am
naschmitz wrote: Does this imply we have a 7 event season or does it apply to 8 event seasons too? If so, in an 8-event season could you carry points from 7 events if you attended all 8?
Yes!
If you attend 1 event, your championship points are based on all the events you attended.
If you attend 2 events, your championship points are based on all the events you attended.
If you attend 3 events, your championship points are based on all the events you attended.
If you attend 4 events, your championship points are based on all the events you attended.
If you attend 5 events, your championship points are based on all the events you attended.
If you attend 6 events, your championship points are based on all the events you attended.
If you attend 7 events, your championship points are based on the top 6 events you attended.
If you attend 8 events, your championship points are based on the top 7 events you attended.
If you attend 9 events, your championship points are based on the top 8 events you attended.
Post by TroyV » Wed Dec 22, 2010 11:59 am
Yes, but what if you do 10 events?
nateh
Post by nateh » Wed Dec 22, 2010 12:07 pm
You'll be tired.
naschmitz
Post by naschmitz » Wed Dec 22, 2010 12:31 pm
Hey Guys, I liked Will's answer. Otherwise I was going to ask Nate if I could restate his answer to my question as "Yes."
Bert Schmitz
nateh
Post by nateh » Wed Dec 22, 2010 12:35 pm
Yes.
Post by WillM » Wed Dec 22, 2010 1:19 pm
naschmitz wrote:Hey Guys, I liked Will's answer. Otherwise I was going to ask Nate if I could restate his answer to my question as "Yes."
Burt, the wording of the rule can be a bit confusing, no doubt.
The BoD spent a lot of time discussing the merits of this rule change, and then spent even longer trying to word it properly. Seems we've still fallen a bit short on at least the wording part.
If anyone has a cleaner and more simple way to state the rule, post it! :) I believe the BoD still has time to vote in a change to the rule's wording so that it would make it in time for the 2011 rulebook.
Anything we can do to make our rule book easier to understand is a win for everyone!
naschmitz
Post by naschmitz » Wed Dec 22, 2010 2:03 pm
If you run more than six events, you cannot include the event with your lowest score in your total for the season.
Bert Schmitz
boltonite
Post by boltonite » Wed Dec 22, 2010 2:33 pm
The rule change (as originally submitted it, and as rewritten) is intended to count attendance points for all events -- only the finishing position points could be dropped from an event. While we want to make the TT series more accessible to those who miss an event, we want to continue to reward those who attend all events. In recent years the BoD has doubled attendance points at some venues (all tracks except NHMS) so attendance points will continue to be a factor in scoring along with the "avg # of cars in class" points. HTH
-FF
Dtangard
Post by Dtangard » Mon Jan 03, 2011 12:54 am
jlwhorf wrote:The highlight of the night was that point scoring rule passed. It basically says: Any competitor that completes more than 6 time trials, will have the lowest point event dropped. Any competitor that completes 6 or less, will be scored on thier total.
What are the limitations on the pressure plate and disc?
#01 T40
Post by Stynger » Mon Jan 03, 2011 11:27 pm
8. Any clutch disc and clutch cover (pressure plate) may be used, providing they are of stock diameter, have the same number of plates and mount on an unmodified flywheel
Dtangard
Post by Dtangard » Tue Jan 04, 2011 3:22 pm
Thanks Les.
#01 T40
