Any Com folks that are experienced welders?
Post by TroyV » Fri Mar 10, 2006 2:21 pm
It doesn't need to be pretty, just some extra side gussets is all I need. Steel ranging from 16ga to 12ga will be fine. Just trim to fit, slap 'em on there, and weld. I have a few cans of spray paint to touch up all the raw surfaces.
Do either of you have a lift? It's hard to do this on jack stands, and I'd rather avoid it... :)
jadams
Post by jadams » Fri Mar 10, 2006 2:57 pm
I can't help with any welding suggestions, but it reminds me of the last time I welded anything. I was welding too close to the fuel lines (which are plastic lines by the way). Well it ignited, and then I had a dripping fireball in my garage. It made for an interesting night. Luckily the only casualty was the fuel line itself. So count me out in offering any words of wisdom. I retired my welding helmet a couple of years ago.
Joel Adams
1995 Pontiac Trans Am
Class T80
gread
Post by gread » Fri Mar 10, 2006 5:45 pm
I have a lift...and plenty of fire extiguishers. Once we start with the bracing. we'll just put in a whole cage, wheel tubs, etc. :shock:
Post by TroyV » Sun Mar 12, 2006 10:48 pm
Gread, what is your schedule like over the next week or so?
Email me at tv2vgt@yahoo.com
Post by TroyV » Mon Mar 27, 2006 11:50 am
Hey Greg. I haven't forgotten about you.. As with all things automotive, a bunch of higher priority things have bumped the welding back a few notches..
I'll contact you after NHIS when things die down a bit. Thanks for your patience..
gread
Post by gread » Mon Mar 27, 2006 7:15 pm
Don't worry Troy. We can have a campfire at any time during the season.
