Greetings all,
This is version 2007-02 of the rule book, and this is the official release.
It will go up on the web site tonight.  Please discard any previous versions.
EDIT: March 3 - Updated to version -03:
http://www.dasilvas.net/com/rules2007-03.pdf
This rule book only has one change, but it appears in two places:
X.3.F  In Street Touring, Vented, Slotted, and Cross-drilled rotors are
   unrestricted.  Use of aftermarket cross-drilled rotors is discouraged.
Then again in
VI.B.4  For Street Touring, Street Prepared, and Prepared, the
  use of aftermarket cross-drilled rotors is discouraged.
Otherwise, this version is the same as the previous one.
													2007 Rule Book Released
									-Herb DaSilva
2004 SRT-4, Blue #62, ST2
				grovefromnh
Rule book
Hi Herb.  Will the rulebook be published and mailed to the member as in the past or is it Internet only. If you have a question at the track about someone's car will you have to find a laptop you can borrow?
						Re: Rule book
We have been inserting into a Drift when possible.grovefromnh wrote:Hi Herb. Will the rulebook be published and mailed to the member as in the past or is it Internet only. If you have a question at the track about someone's car will you have to find a laptop you can borrow?
But that would depend on the Drift schedule.
Any Steward should have a copy on hand at an event,
and Mark Swinehart (the Registrar) typically keeps a copy
with him as well.
-Herb DaSilva
				enjoythemusic
Re: Rule book
Herb,
Excellent! Agree about drilled as those things can play a NASTY 'connect the dots' game. Solid or slots are the way to go for sure and glad to see COMSCC infer it in the rules.
