Turn 3 Thompson
Turn 3 Thompson
With a heavier car, with good mechanical grip, is it faster to not stap the breaks in turn 3, and just hang on, or stab to begin rotation? It seems subtle depending on tires and track moisture ?
-Aric
1997 Ford Mustang SVT Cobra ITE/T1/AS/T70
2015 Ford F150
2015 Ford F150
jvangelder
Re: Turn 3 Thompson
I dont stab the brakes, but do trailbrake heavy into 3 to get some early rotation. I feel like my car benifits more from a good run out of 4 than the slight run from 3, so i in a way throw away 3 depending on traffic etc.
Also, did i see you registered for the scca school at thompson?
Re: Turn 3 Thompson
Probably should replace "stab" with "tap". I've been trying the turn with and without a brake tap. Some lap time data should help figure out which is faster. Also will try some trailbraking.
Yes, I completed the SCCA school last Friday. Rained all day, good times!
-Aric
2015 Ford F150
2015 Ford F150
