Drive by wire mod.
Neonacr
Drive by wire mod.
Post by Neonacr » Sun May 26, 2013 5:08 am
Would a device such as a sprint booster, intended to reduce throttle lag incur a point penalty?
Re: Drive by wire mod.
Post by Chrispy » Sun May 26, 2013 8:17 am
I don't think so.
All it does is increase the voltage relative to the pedal position, so if you press the pedal 25% you actually get 50%. If the car has an ECU lag or a lag in the intake throttle servos then it will do nothing to help that.
In other words it does nothing that can't be replicated with the right foot.
Neonacr
Post by Neonacr » Sun May 26, 2013 9:21 am
I had the Sprint Booster on my 2.0 Mazda 3 prior to having a Dynotronics tune, made some improvement but not as much as the Dynotronics work. The 2 is a real hoot to drive with the exception of absolutely terrible lag, no smooth way to rev match for a downshift. I read of one driver that depresses and holds the pedal down until he gets engine response for downshifts but this seems cumbersome and distracting to me. I have no points left for an ECU upgrade and as this car is not remotely competitive in T30 it would be hopeless to bump up a class, so the Sprint is my last resort.
Post by Chrispy » Sun May 26, 2013 10:01 am
Right, the only thing that can properly cure the lag is a tune.
If the sprint booster helps work around the deficiency by reducing how far you have to depress the pedal to blip on the downshift then I see no technical issue with it. I'll ask Tom for the official word.
Post by Stynger » Mon Jun 10, 2013 2:51 pm
Chrispy wrote:Right, the only thing that can properly cure the lag is a tune.
So I can modify my throttle body by changing to a variable throttle cam to change my pedal feel? :shock:
1 point Non‐Factory Trim/modified throttle body or carburetor
Post by Chrispy » Mon Jun 10, 2013 3:53 pm
Stynger wrote: So I can modify my throttle body by changing to a variable throttle cam to change my pedal feel? :shock:
If you were to change just the throttle cam and nothing else then I suppose that would fall into the same category. I believe the intention of the rule is prevent enlarging the throttle body opening, changing the linkage shouldn't be penalized in my personal opinion.
