Air Filter in SS
W0lfK1n
Air Filter in SS
Post by W0lfK1n » Sat Nov 29, 2003 10:34 am
I have a clarification question about the Air Filer requirements in Showroom Stock.<br>
<br>
In the Rules under Showroom Stock/Running Gear/Engine and Drive Train #5 it says:<br>
<br>
Any make oil, air, and/or fuel filter elements are allowed.<br>
<br>
My question is that does this only apply to DropIn replacements? or can you attach a K&N Cone Air Filter? I do understand that this is legal only if there are no other changes: for example - removing/changing the stock Air box, intake pipe, etc. The reason I ask is because I can (and have) attach a Cone to the end of my intake pipe without any changes to the Stock Configuration.<br>
<br>
Thanks All:<br>
Eldon<br>
<br>
<p></p><i></i>
comsccAdmin
Re: Air Filter in SS
Post by comsccAdmin » Sat Nov 29, 2003 11:05 am
I assume that you had to disconnect the pipe from the stock air box<br>
to attach the cone. So, that would not be legal. The overriding<br>
qualification is this first sentence from the 4th paragraph under IX.:<br>
<br>
"The competitor may be required to provide a factory shop manual <br>
of the competing vehicle's model and year to aid the Event Stewards <br>
in determining what is the "as delivered" configuration."<br>
<br>
So, if the "as delivered" configuration must be changed (i.e. disconnecting<br>
the intake pipe from the air box) to fit the cone filter, then it's not legal.<br>
<br>
Great question, though! :-)<br>
<br>
-Herb<br>
<p></p><i></i>
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Google [Bot] and 1 guest
