What program do you guys use to edit GoPro video ?
thanks,
Aric
GoPro video editing
GoPro video editing
-Aric
1997 Ford Mustang SVT Cobra ITE/T1/AS/T70
2015 Ford F150
2015 Ford F150
Re: GoPro video editing
Windows Live Movie Maker has all the basic features you need and is very easy to use. It should already be on your PC.
I used Adobe Premier but it was a pain in the butt. So I also went back to free Windows Live Moviemaker.wizzman wrote:Windows Live Movie Maker has all the basic features you need and is very easy to use. It should already be on your PC.
I use Avidemux http://en.wikipedia.org/wiki/Avidemux
It's free and has a lot of features. I didn't realize Windows movie maker did MP4 editing
John F
#167 SA FFR roadster
I use AVIDemux as well for quick trimming. Is is extremely quick when it is just copying unaltered stream data.
A few quirks it has that you need to get used to:
- Need to set output to MP4. Output as AVI doesn't work right.
- Can only trim start/stop points on key-frame (I-frame) boundary markers. There are controls to advance to next I-frame. Using drag method always lands on an I-frame.
Trimmed output can then be fed into movie maker or RaceRender or uploaded directly to the Tube.
Resolution78
- Fast Lapper
Same herewizzman wrote:Windows Live Movie Maker has all the basic features you need and is very easy to use. It should already be on your PC.
Resolution78 wrote:Same herewizzman wrote:Windows Live Movie Maker has all the basic features you need and is very easy to use. It should already be on your PC.
+2 for Movie Maker.
FYI, the first time you load up the file, it takes a while. My files are ~1.5GB for each 20 minute session in 720p. Movie Maker will appear to be hung up, but its loading up the file. Takes ~3-5minutes depending on PC speed.
#29 T40 Miata
