THE CAR IS SOLD, but there are spares available- Scott C. has first dibs on rims/tires.
This is the black #09 car with the oil leak that I can not find. I have over $30,000 in reciepts for this car- thankfully mostly spent by the original owner- and a grand total of 2 or so hours on track. I have been frustrated with this car for the last time. Maybe someone smarter than I can figure it out. The power, handling and brakes are fantastic. The car is cross weighted and aligned for a 210# driver. Just get it to not catch on fire and you have a great car.
331 stroker motor- DSS forged pistons, twisted wedge heads, Anderson Ford Cam, 1.6 roller rockers, DSS support girdle and windage tray, Canton road-race pan
Tremec 3550 5 speed- new Cenetrforce Dual Friction clutch
Torsen T2R rear differential with 3.55 gears
Aluminum driveshaft
Maximum Motorsports suspension: panhard bar, torque arm, camber plates- too much to list.
Bilstein coil overs
Brembo 4 piston 13” front brakes. Hawk DT70 front pads Hawk Blue rear pads.
Aeromotive fuel system. 15 gallon fuel cell.
Dyno sheet from 8/18/12: 339 rwhp 371 rwtq.
Lots of spares: rims, tires, exhaust etc.
Reciepts and build documentation provided.
$5,000 Scott 978-609-5590.
THIS IS NOT A STREET CAR
1990 Mustang*** SOLD*** spares available
Re: 1990 Mustang
Dan Darcy needs to buy this car! Wait, does it still have AC and a sound system?
Re: 1990 Mustang
TOO MUCH POWER for me Cy, remember I'm an old man who just putts around in a 1.8 liter Toyota powered plastic play toy.
Scott -- I hope you plan on buying something else and coming out and play with COM
Re: 1990 Mustang
Scott, are the rumors true? Are you finally coming around to the miata crew? That's Great!
Re: 1990 Mustang
Still haven't given in to the hysteria- as much as they make sense- of driving a Miata. I have a BMW 318ti that has been begging to go racing. That's probably next- although there are Mustang forces at work on me still.
Re: 1990 Mustang
You know my vote! When not an Alfa, always a non-Miata!offcamber09 wrote:Still haven't given in to the hysteria- as much as they make sense- of driving a Miata. I have a BMW 318ti that has been begging to go racing. That's probably next- although there are Mustang forces at work on me still.
Re: 1990 Mustang
Ok if you start to part it out I will take the spare wheels,Torsen T2R,maybe the tremec, let me know when you ready and I will help you strip it.
