Trailer tires
escortracer
escortracer
grovefromnh
Re: Trailer tires
Dpends if trailer is empty or loaded. Where trailer is very light when empty, it will REALLY bounce if driven with 'loaded' pressures. I think 35psi loaded, 30 psi empty.
30+ yr member
nhsilversti
Re: Trailer tires
most trailer tires are 50psi cold.
radial tires you can get away with a little lower but bias ply you need to religiously check they are at 50psi cold or they will overheat and blow out easily.
ted
ted
Re: Trailer tires
Whatever it says on the sidewall...50-something whether the car is on it or not. Mine weighs 1600# empty and doesn't bounce around at all.
