Trailer tires
escortracer
Trailer tires
Post by escortracer » Tue Jun 26, 2012 9:29 pm
Ok the question is what cold pressure do you run your trailer tires?
T4 268
escortracer
Re: Trailer tires
Post by escortracer » Wed Jun 27, 2012 5:45 am
Oops double post.
T4 268
grovefromnh
Re: Trailer tires
Post by grovefromnh » Wed Jun 27, 2012 6:11 am
Dpends if trailer is empty or loaded. Where trailer is very light when empty, it will REALLY bounce if driven with 'loaded' pressures. I think 35psi loaded, 30 psi empty.
30+ yr member
nhsilversti
Re: Trailer tires
Post by nhsilversti » Thu Jun 28, 2012 3:54 pm
most trailer tires are 50psi cold.
radial tires you can get away with a little lower but bias ply you need to religiously check they are at 50psi cold or they will overheat and blow out easily.
ted
CP
Re: Trailer tires
Post by CP » Thu Jun 28, 2012 9:25 pm
Whatever it says on the sidewall...50-something whether the car is on it or not. Mine weighs 1600# empty and doesn't bounce around at all.
