1992 Miata: OBD1 or 2?
Post by 6PAK72 » Sat Jun 09, 2012 11:11 am
Trying to find code reader plug, and it doesn't look like anything unde the dash matches....
JB
Re: 1992 Miata: OBD1 or 2?
Post by Mark Swinehart » Sat Jun 09, 2012 11:19 am
Here's how you check the codes in your miata. There isn't a code-reader-jack per-se in the OBD I miatas that I know of. The diagnostics port under the hood is more a set of specific wires in the electrical system to use for specific tests - either to put put the ECU into a diagnostics mode or test certain signals/voltages so you don't have to hunt for them in the wiring harness. Anyway, here's a link to a helpful article:
http://www.miata.net/garage/faultcodes.html
Post by jeffw » Sun Jun 10, 2012 4:28 pm
Since you have a Megasquirt ECU, you have neither :-)
It's a standalone ECU :-)
