WTB Miata gearshift rubber boot
Post by 6PAK72 » Mon Dec 26, 2011 12:04 pm
Anyone have one kicking around? Mine is torn all the way around.
Re: WTB Miata gearshift rubber boot
Post by jeffw » Mon Dec 26, 2011 12:52 pm
Are you set up w/ Mazdaspeed?
Post by paultg » Tue Dec 27, 2011 7:37 pm
Post by CP » Fri Dec 30, 2011 3:04 am
I'm sure you know this, but there are two rubber boots. One bolts to the top of the trans tower and the other to the top of the trans tunnel on the tub. Don't forget to put some fluid into the tower before sliding in the shifter.
Post by 6PAK72 » Sat Dec 31, 2011 11:05 am
The tranny boot that needs the grease, thanks, Cy.
I am set up with MSpeed, but I needed it before I could put together a larger worthwhile order.
Post by jeffw » Sun Jan 01, 2012 2:53 pm
6PAK72 wrote:The tranny boot that needs the grease, thanks, Cy.
I'm ordering stuff on Tuesday if you want me to grab stuff for you.
