WTB Miata gearshift rubber boot
Anyone have one kicking around? Mine is torn all the way around.
Re: WTB Miata gearshift rubber boot
Are you set up w/ Mazdaspeed?
Jeff, sometimes I find www.finishlineperformance.com is cheaper than www.mazdamotorsports.com
If this is the one ($22): http://parts.arlingtonmazda.com/product ... 1B%29.html
Or this one: ($28): http://parts.arlingtonmazda.com/product ... 0A%29.html
I'm sure you know this, but there are two rubber boots.  One bolts to the top of the trans tower and the other to the top of the trans tunnel on the tub.  Don't forget to put some fluid into the tower before sliding in the shifter.
The tranny boot that needs the grease, thanks, Cy.
I am set up with MSpeed, but I needed it before I could put together a larger worthwhile order.
I'm ordering stuff on Tuesday if you want me to grab stuff for you.6PAK72 wrote:The tranny boot that needs the grease, thanks, Cy.
