Expected life on Hoosiers?
jadams
Post by jadams » Tue Feb 07, 2006 12:55 pm
I found a good deal on some Hoosiers (315 35 17 and 275 40 17) for my TA. I was wondering how much life I could expect out of these tires before I buy them. Approx how many event days could I expect to get out of them compared to like a Kuhmo V710? I know it is all depends on what I do to them, but I was just wondering a rough order of magnitude.
Joel Adams
1995 Pontiac Trans Am
Class T80
gread
Post by gread » Tue Feb 07, 2006 1:36 pm
I'm assuming you wear tires at a pretty good clip if you're a T/A in SPA. I run a SPA BMW which is a bit lighter and I can get 1 week-end normally, sometimes 2 on the S04 Hoosiers. The S05 is finally out this year in my size and I'm hoping to see improved wear patterns. The S03 used to get 3-4 events, the S04 just didn't wear well. They Hoosiers are definitely faster than other tires, but come with a significant tire budget.
jadams
Yikes!
Post by jadams » Tue Feb 07, 2006 6:18 pm
I knew that they wore than Kuhmo's, but I didn't think that they were that bad!! :shock: I guess I will have to stay away from them then. If I only got one weekend out of a set of tires....I am sure that my wife would like that one. I will just have to stick with the Kuhmo's then.
Thanks for the info!
Joel Adams
Class T80
Hoosiers vs. 710s
Post by offcamber09 » Tue Feb 07, 2006 6:27 pm
Here's the view from the other end of the racing world (budget-wise). I ran the 710s at every COM event last year and will use them again this year...plenty of meat on them. The Hoosiers are faster...but will flat spot to the cords instantly on brake lock-up. Excluding flat spots- I could come close to getting a season out of the S03. I have not run the newer hoosiers for a full season. I still get "some" grip with Chris Conacher's 2-3 year old hand-me-downs as my back up tires. There's life in them there tires.
Post by offcamber09 » Tue Feb 07, 2006 6:30 pm
Sorry I forgot to add that I found the 710s to fall off rather dramatically after 5-6 laps in a Mustang at 3050# without driver. Great for time trial not for endurance.
jadams
Post by jadams » Tue Feb 07, 2006 7:59 pm
Hey Scott,
That Mustang of yours only weighs 3050#?? Gees, I guess I need to put my pig on a diet. I have remove a couple of hundred pounds from my TA and it still weighs 3415# without me in it! I guess I will have to remove the rear axle or something. That is probably worth a couple of hundred pounds. :D
Joel Adams
Class T80
Post by offcamber09 » Tue Feb 07, 2006 9:15 pm
jadams wrote:Hey Scott,
The car is about as gutted as I can get it. I'll trade you 100# for 100 of your extra hp :lol:
Whoo-hoo
Post by dinoracer » Thu Feb 09, 2006 10:59 am
Hey Scott, has Coleen seen your new avatar?? :lol: :lol:
christine
Post by christine » Thu Feb 09, 2006 11:39 am
So where do you all get the sleazy, obnoxious avatars? I figure if you can't beat 'em, join 'em. I'm thinking that as long as it's a cartoon it's okay, right?
Christine
Post by offcamber09 » Thu Feb 09, 2006 2:50 pm
christine wrote:So where do you all get the sleazy, obnoxious avatars? I figure if you can't beat 'em, join 'em. I'm thinking that as long as it's a cartoon it's okay, right?
Christine
I knew it wouldn't be long before that got a response. Agreed I thought the cartoon aspect of it made it acceptable. I saw that Raj changed his avatar from Barney doing the nasty. I had that file as a gif for years and it was too big to use on our forum. I finally had a computer geek friend of mine reduce it in size so I could use it.
No Coleen hasn't seen it on this site, but she's seen it. She's a good sport.
rajito
Post by rajito » Thu Feb 09, 2006 3:52 pm
christine wrote:I'm thinking that as long as it's a cartoon it's okay, right?
As long as it's not one of a prophet.
Nyuk nyuk. :shock:
#66 SuperSlowGT
Silver 2004 Nissan 350Z
christine
Post by christine » Thu Feb 09, 2006 4:44 pm
Rather than lower myself to sleaze, I opt instead to bring some sorely-needed culture to the group. Please enjoy this picture of one of the most beautiful sculptures of all time.
Christine
BTW I thought Barney was funny.
rajito
Post by rajito » Thu Feb 09, 2006 4:59 pm
Bravo bravo! That looks like Alex. I mean, the face. :oops:
#66 SuperSlowGT
Post by WillM » Thu Feb 09, 2006 5:06 pm
offcamber09 wrote:Sorry I forgot to add that I found the 710s to fall off rather dramatically after 5-6 laps in a Mustang at 3050# without driver. Great for time trial not for endurance.
Scott, have you run on Toyo RA-1 tires? They are grippy to the cord and do not go away, at least on my 2500-lb Miata...
Post by offcamber09 » Thu Feb 09, 2006 8:57 pm
I used them on a VW Rabbitt at one point. I thought they were more like Victoracers while the 710s were aimed at the Hoosiers. It seems the 710s are better suited to the lighter cars, but I can't complain with the wear characteristics of the tire.
Christine kudos for the "equal time". Somehow I now feel less inferior. :lol:
