tju-vette
Post
by tju-vette » Wed Sep 26, 2007 1:41 pm
Like this:
or is tieing down by the frame better?
Just got a trailer for my car.
Post
by Mark Swinehart » Wed Sep 26, 2007 2:14 pm
Those are the same type of tie-downs I been using on my tow dolly for the last six years and never had a problem.
Post
by StephanAlfa » Wed Sep 26, 2007 2:16 pm
I wish I had these. I hear they are great.
I use the body straps and ended up tying them on the tires as I could not reach certain parts of the car w/o interfering with brake lines, etc.
Some use the body tied-down and wrap it on the wheel but turns out mine does not have an opening wide enough also.
Did you get them at E-trailer.com?
tju-vette
Post
by tju-vette » Wed Sep 26, 2007 2:36 pm
StephanAlfa wrote:Did you get them at E-trailer.com?
Haven't gotten anything yet but there are a number of places on line that have them. Jegs had a variety of styles for different width tires.
Post
by Stynger » Wed Sep 26, 2007 3:33 pm
I think these are OK if your trailer is set up for it (like the car dolly) front and rear D rings at the wheels.
The car will bounce around on the suspension over bumps.
Post
by dinoracer » Thu Sep 27, 2007 2:18 pm
These are regular straps, not the "over the tire ones"
http://www.pegasusautoracing.com/produc ... oduct=2351
(sorry, picture post challenged...)
I just bought a set from pegasus and am really impressed with the quality, especially compared to the Summit/Jegs ones I had before. Made in USA, heavier construction, and not much more money. They are running a special right now, basically everything you need in a storage container for $ 125
enjoythemusic
Post
by enjoythemusic » Thu Sep 27, 2007 4:12 pm
Another vote for Pegasus. Get lots of stuff from them and have 'shopped' them to save a few bucks and what usually arrived from the 'saving' place is not as good quality as Pegasus for a few sheckles more.
Post
by StephanAlfa » Fri Sep 28, 2007 8:51 am
Mark Swinehart wrote:Those are the same type of tie-downs I been using on my tow dolly for the last six years and never had a problem.
Yeah right Les .. Mark's car has no suspension...has no engine either ... and not much of a body to speak for
Post
by Mark Swinehart » Fri Sep 28, 2007 10:49 am
I take offense at that and you are misinformed – my car has an engine.
Maybe you didn’t see the entire engine – a lot of the parts are on the floorboard in front of the passenger seat.
BTW – I’m planning on dropping the oil pan tonight to see if I can find the rest of the shims and parts.
