Thoughts on driving on R compounds to the track
sillyspheres2
Post by sillyspheres2 » Mon Oct 17, 2005 9:47 am
Guys:
What are your thoughts on mounting my R compounds (v710s) at home and driving on them to NHIS? The purpose of this would be to save time at the track and avoid a repeat of the problem I had at Tremblant where I ended up missing the registration deadline and getting in trouble with Mark :oops:
The total drive would be 90 miles on the highway.
Or is a better solution just to wake up earlier and learn to swap tires more quickly?
thanks,
Brad
Post by WillM » Mon Oct 17, 2005 10:53 am
If you do not HAVE to drive on the r-compounds, then I wouldn't. The last thing you'll want is to have a tire problem on the way to the track which would prevent you from running for the day.
That said, I drive on my 'rain' tires (full tread) and tow my dry tires on a small trailer. Other than the threat of getting a flat, using up good rubber, and generating unnecessary heat cycles, there is nothing wrong with driving the r-compounds on the street. If the weather is bad (rain, cold, etc.), then highway/street driving can get a little dicey. The problem is even worse if the tires are at race-depth.
On the way home from Tremblant, one of my rear tires blew out. I would have preferred to blow out a street tire as opposed to one I use on track. Oh well - at least the most important tires were on the trailer.
In general, I'd say don' t do it. How long does a tire swap take you? Mine are done in 15 minutes, if I take my time.
BrakeL8r
re: Thoughts on driving on R compounds to the track
Post by BrakeL8r » Mon Oct 17, 2005 11:05 am
Don't do it. For one, if you get pulled over, you'll get a ticket (even thought their DOT tires), because the tread level is bound to be below the legal limit. Secondly, if you pick up a nail/screw, you're probably gonna have to chuck the tire, whereas a street tire you can get plugged.
--Michael
ST4 Miata #176
Georgethefierce
Post by Georgethefierce » Mon Oct 17, 2005 11:42 am
if there is no threat of rain this weekend I'll be driving up on Victoracers and towing my V710's on my tiretail
the guys above are right though and especially with a softer compound like the V710's just not worth the risk or the wear
SillySpheres
Post by SillySpheres » Mon Oct 17, 2005 12:27 pm
thanks for the advice guys. I think what I will do is just try to get there early and learn to do the swap more quickly.
kfoote
Post by kfoote » Mon Oct 17, 2005 12:54 pm
Having taken my dad's 94 Supra Twin Turbo in BFG R1's through the median strip of I-89 on the way back from Tremblant a few years ago, I would only reccommend it if there is sufficient tread on the tires, or there is zero threat of rain.
Kevin Foote
#64 SB Nissan 350Z
1998-2003 Chief of Tech
1998-2002 BOD member
JackFFR1846
Post by JackFFR1846 » Wed Oct 19, 2005 10:41 am
Brad,
Lotsa help is available at the track to do a swapover. I'll help. It takes me maybe 15 minutes to unload my car off the trailer and get the tech sticker. I've run track tires on the street long ago. They are sticky enough that the front tires pick up every screw and nail on the road and pitch them at the rears. The rears catch them. Not a good thing.
You're my victim.....uh......I mean student Saturday. :D
jack
sillyspheres
Post by sillyspheres » Wed Oct 19, 2005 11:00 am
JackFFR1846 wrote:Brad,
jack
Cool. I'll look for you. I'll be in the White RSX Type S.
Re: re: Thoughts on driving on R compounds to the track
Post by offcamber09 » Wed Oct 19, 2005 1:14 pm
"street tire you can get plugged."
I know I sound like a broken record, but please don't bother getting tires plugged. If you do you might as well try and find some bias ply tires and really laugh in the face of technology. PATCHES ONLY (yes I'm yelling).
therooster
Post by therooster » Wed Oct 19, 2005 6:04 pm
Scott,
Do you want to see my 16.5 plugged bias plystudded studded snow tires mounted on 16 rims?
Chris A. :lol:
16.5 tires on 16" rims
Post by offcamber09 » Wed Oct 19, 2005 7:59 pm
I have a huge dent in the corrogated steel roof of my shop (20' high) from a tire blowing off the rim as a moron former tire changer tried just that. Would have killed him if he was leaning over the tire.
Chris, got to love those bias snows- especially when you use studs that are too long for the the stud holes.
