Nope, since current rules do not allow updating/backdating of engines. If the new class structure were to be adopted, then I would propose the following:SSNH wrote:Kevin, under the proposed Combo of the ST3 and 4 would this make the 2.0 swap into the 2nd Gen Sentras legal?Georgethefierce wrote:Kevin, under the proposed Combo of the ST3 and 4 would this make the 1.8 swap into the 1st Gen Miatas legal?
COM Sports Car Club
2005 Rules, Regulations and Car Classifications
Rev: 2005-01
OLD RULE
Section X. STREET TOURING
Updating and back-dating of components are not allowed in Street Touring (ST), unless specified below. The original engine (or direct replacement) that was manufactured with the car must be used.
NEW RULE
Updating and back-dating of components are not allowed in Street Touring (ST), unless specified below. [REMOVE: The original engine (or direct replacement) that was manufactured with the car must be used.]
ADD:
9.
Updating and back-dating of engine assembly is allowed provided that the replacement engine was offered in the same make, model, and chassis of the vehicle it is being installed into. Engine assembly is defined as a 'dressed engine' and includes longblock, intake manifold, electronics & wires, belt-driven accessories, and any other OEM-type parts required for the engine to function as it would in its original vehicle. The engine must be a 'drop-in replacement', meaning no alteration of firewall or other sheetmetal is permitted. Engine must be transferred as a unit, mix and matching of parts is prohibited. Cars with updated/back-dated engines are reclassified into the appropriate ST class of the replacement engine.
Purpose for rule change:
The consolidation of similar cars with different-sized engines into the same class has created a disparity between competitors within a given class. This rule closes that gap by effectively allowing a car to move up to its next 'trim level' ie: 'LX' to 'GT'. The addition of this update/back-date rule also compliments the current update/back-date rules of differentials and brakes within the ST class. Furthermore, the addition of this rule promotes the idea of fair competition within the club and helps gain support for the larger overall classification changes. Classes become more populated while and at the same time, one type of car is not benefitted more than another.
