Miata tech question - computer self-diagnostic codes?
peterfontana
Post by peterfontana » Mon Jun 18, 2007 10:05 am
Hi,
I have a 1993 Miata that has recently developed a tip-in stumble. The service manual says to check codes first, and shows some fairly specific looking diagnostic gear to accomplish this.
So I immediately closed the manual, crossed my fingers, bought an O2 sensor, and discovered that wasn't it.
Is there a "jump two pins and then count the blinking lights" type of work-around to read computer self-diagnostic codes? If not, does anyone around Eastern Mass have the required hardware that I could borrow (or is there a reasonably priced alternative)?
Thanks for any help,
- Peter
LDP82
Post by LDP82 » Mon Jun 18, 2007 12:12 pm
yes you can jump two pins (i think ground and ten) and count the CEL blinks. look around on miata.net. i have an OBD2 miata so i dont remember what you have to do but its not hard.
Racing makes heroin addiction look like a vague longing for something salty - Peter Egan
Post by WillM » Mon Jun 18, 2007 6:22 pm
I'd check for vac leaks.
Is the CEL on? This is the link Luke was talking about:
http://www.miata.net/garage/faultcodes.html
peterfontana
Post by peterfontana » Tue Jun 19, 2007 8:20 am
Thanks for the info.
Post by dinoracer » Tue Jun 19, 2007 2:04 pm
I think you need to dump that girlie car :wink: and bring the Mustang back to the track... :lol: :wink: :wink:
peterfontana
Post by peterfontana » Tue Jun 19, 2007 3:14 pm
After a quality shop did a freshening of the short block (new hone, rings, etc) and valve guides/seals, I'm still seeing a lot of oil smoke, especially on decelleration. Too much to race. I even resorted to a new mighty demon carb to replace the Holley 750 double pumper I had. I'm bumming out, Tom. Got any suggestions?
Post by dinoracer » Tue Jun 19, 2007 3:29 pm
I feel that pain, I'm having the same only worse problem on my most recent engine. (There's a long story over the past year).
I your case, I'd ditch the pcv system, run a hose from each valve cover into a catch can with a breather. about $ 100 in parts from Summit racing or jegs, including cheap crappy stamped steel valve covers
