Could you give me an opinion on acceptablility of moving the seat cushion forward an inch or so to allow acess to the belt mounting points?
I appreciate your consideration.
chaos4NH wrote:I apologize for any discomfort caused by the tone of my post.I am merely concerned that a safety item, being snug in your seat for better car control, would not receive a more detailed look. In light of the fact that a roll bar or cage, both of which can help stiffen the chassis, are allowed, I felt that the removal of 6 lbs would be a minor issue.
Could you give me an opinion on acceptablility of moving the seat cushion forward an inch or so to allow acess to the belt mounting points?![]()
Why are targa tops considered to be different from fixed roof cars? I have a 93 vette and this rule may exclude me from running with COM.chaos4NH wrote:There is mention that targa tops must be 2" higher than the top of the helmet
tju-vette wrote:Why are targa tops considered to be different from fixed roof cars? I have a 93 vette and this rule may exclude me from running with COM.chaos4NH wrote:There is mention that targa tops must be 2" higher than the top of the helmet
I ran the July NHIS event last year and asked one of the tech inspectors (being new I can't remember who) told me that that rule didn't apply because my roof was in place and no roll bar was present.
Is there any clarification available on this? TIA.
Understood, in reading Section VI.F.6 I see the 2" rule. Does this require 2" clearance on the inside from helmet to inside of roof or just 2" from helmet top to highest roof point?HerbD wrote:Targa roofs are different because in a rollover, the roof panel WILL shatter or crush inwards. On fixed-roof cars the roof may hold up OK in a light rollover. So, we want some space up there.
tju-vette wrote:Understood, in reading Section VI.F.6 I see the 2" rule. Does this require 2" clearance on the inside from helmet to inside of roof or just 2" from helmet top to highest roof point?HerbD wrote:Targa roofs are different because in a rollover, the roof panel WILL shatter or crush inwards. On fixed-roof cars the roof may hold up OK in a light rollover. So, we want some space up there.
I am currently running the clear roof panel and have also lowered the seat so it mounts directly to the floor. However, @ 6'4" I take up a lot of that extra room.
What would be the best way to make sure that I'm compliant before an event?
Thanks for the feeback.
