Thanks Tom
Thanks Tom
Manchester Engine Rebuildersdinoracer wrote:The continuing saga of the broke Mustang motor...
Thanks Tom
290 Clay Street
Manchester, NH 03103
Tel – (603) 669-2843
Contact: Gary
enjoythemusic
Thanks Guys
Thanks Tom
Thanks Tom
enjoythemusic
LOL! Bet you that it provided the 'fix' you were looking forLDP82 wrote:KTR is a great shop, come in with a head to be fixed leave with a Noble
...or more
Hmmm, a Noble you say....
Just to finish the original focus of this thread
KTR European's website looks really expensive, so I haven't called them.
I love to learn things the hard way
enjoythemusic
Many of us have been there, you are not alone. Please believe me when i say, "It could have been a different mistake that cost MUCH more."dinoracer wrote:Just to finish the original focus of this thread...
I love to learn things the hard way![]()
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 1 guest
