Post by dinoracer » Sun Jan 28, 2007 8:30 pm
Thanks Tom
SSNH
Post by SSNH » Sun Jan 28, 2007 9:17 pm
dinoracer wrote:The continuing saga of the broke Mustang motor...
Thanks Tom
Manchester Engine Rebuilders
290 Clay Street
Manchester, NH 03103
Tel – (603) 669-2843
Contact: Gary
MMiskoe
Post by MMiskoe » Sun Jan 28, 2007 11:25 pm
R&R in Londonderry NH.
(603) 434-0579
Not likely to be the cheapest, but I'm sure they can help you if it can be done.
Post by jlwhorf » Mon Jan 29, 2007 8:27 am
Tom, you could try R&L in dover 742-8812. I believe they can do spray welding on cast iron. Going through the water jacket is pretty nasty to fix considering how thin the sbf walls are to begin with.
Jonathan
enjoythemusic
Post by enjoythemusic » Mon Jan 29, 2007 3:47 pm
Enjoy the Track,
Steven R.
http://www.EnjoyTheTrack.com
Post by jlwhorf » Mon Jan 29, 2007 4:50 pm
Tom, You could also try Ted Wingate at Precision Balancing on 111 in Hudson. I don't have the number, but he is located in the industrial park behind 3D autoworks. He machined a shortblock for me years ago and it lasted a long time.
Jonathan
LDP82
Post by LDP82 » Mon Jan 29, 2007 5:51 pm
KTR is a great shop, come in with a head to be fixed leave with a Noble :)
Racing makes heroin addiction look like a vague longing for something salty - Peter Egan
Post by dinoracer » Mon Jan 29, 2007 7:22 pm
Thanks Guys
Thanks Tom
Tsurara
Post by Tsurara » Mon Jan 29, 2007 7:40 pm
If you are willing to make the trip, why not give fellow COM members Alex and Bill a call at Dent Sport Garage in Norwood, MA?
+1 (781) 551-3399
Charles K.
SSNH
Post by SSNH » Tue Jan 30, 2007 8:39 am
dinoracer wrote:R & R suggested R & L in Dover also.
a few years ago, a bmw shop outsourced some aluminum welding on my engine to r&l.
cuda6666
Post by cuda6666 » Tue Jan 30, 2007 9:58 am
If that's the same shop that Ted Wingate owns (or used to own??), they fixed a hole between the water jacket and the oil gallery in my Cuda engine.
enjoythemusic
Post by enjoythemusic » Tue Jan 30, 2007 2:34 pm
LDP82 wrote:KTR is a great shop, come in with a head to be fixed leave with a Noble :)
LOL! Bet you that it provided the 'fix' you were looking for :)
...or more :(
Hmmm, a Noble you say....
Enjoy the Track,
Steven R.
LDP82
Post by LDP82 » Tue Jan 30, 2007 6:44 pm
well, they have a v12 and a flat 12 up stairs... as well as some other track toys all around and a 996 GT3 cup car for sale for $89k i dont think you could go wrong!
Post by dinoracer » Tue Jan 30, 2007 7:50 pm
Just to finish the original focus of this thread :) ...
KTR European's website looks really expensive, so I haven't called them. :lol:
I love to learn things the hard way :roll: :roll:
enjoythemusic
Post by enjoythemusic » Thu Feb 01, 2007 9:35 am
dinoracer wrote:Just to finish the original focus of this thread :) ...
Many of us have been there, you are not alone. Please believe me when i say, "It could have been a different mistake that cost MUCH more."
Enjoy the Track,
Steven R.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
