2017 Honda Civic Type R
Hello,
This season i have retired my trusty but aging 2009 Civic Si for a 2017 Civic Type R.
I cannot select the car in the Classification tool, assuming it has not been added yet.
Most of the modifications are minor like tires wheels brake pads a rear sway bar and some different springs.
Would love to know where this car is going to be classes so i can start fabricating some stickers haha!
looking forward to 2019!
17 FK8 CTR
Re: 2017 Honda Civic Type R
Shoot an email to rules@comscc.org and they should be able to help you.
I heard they are only allowed in Super Class.
Any update on the Type R classification ?
May be a 2019 that wants to run with he club this year,
-Aric
1997 Ford Mustang SVT Cobra ITE/T1/AS/T70
2015 Ford F150
2015 Ford F150
My guess would be a base class of T70, not sure if the rules alias got back to you but I'd think that's a good fit for the car.
Hi guys. We took care of the points offline. The 2017 Civic Type R comes out to 78.1 points. It'll be in the 2020 Rule Book.
#01 T40
#01 T40
Hey,
There must have been some sort of confusion because i am looking at a 2019 civic type r that is registered for NHMS and it is apparently in T60? is it a T60 or T70 car because that changes everything from a classing standpoint....
Eddy
Eddy
17 FK8 CTR
Eddy, talk with an event steward on Saturday. The car you are questioning is probably a few 100 lbs over curb weight (so neg points back), and might also be on a tire that gives some points back. So if it was a base assessment of low 70 points, it could be high 60s in points depending on setup.
Stock it comes with 245 Conti SportContact 6 (UTQG 240) so that's -7 points for compound and -1.3 for section right there. More points for weight of driver and fluids. It could easily drop into the T60's if it's mostly stock.
Apparently the fronts take a beating: https://www.caranddriver.com/news/a2861 ... tire-wear/
Graham Cranston
#76 T50 | 2013/15 FT86
Will do. Interesting that it started as a 78.1 but now is much lower...
17 FK8 CTR
That's how the classing works out for all cars. The showroom assessment assumes certain tire section (by class) and compound (zero-point for all cars), and the curb-weight. Because not all gas tanks are full, and not all COMers weigh the same, we also adjust weight. Near-stock cars on street tires will e running below their baseline assessment. My BRZ has 52 points showroom assessment but I'm able to run in T30 with the right tires and competition weight.
Graham Cranston
Gotcha...
I must be doing my weight wrong or have the tires in the wrong category for stock.
17 FK8 CTR
If your tires aren't specifically listed, use the UTQG number (and tire section) to assess points. If they are listed then use that entry. For weight, you can make a reasonable guess at how much your competition weight exceeds your curb weight by adding your weight and 6 lbs/gallon of fuel. Better to underestimate than overestimate. You can check at a TT next year as COM now has scales!
Email the stewards if you have more questions.
Graham Cranston
I actually did go on the scales this past weekend and to my surprise i was very close !
I am now understanding what i did differently!
Thanks for the help!
Eddy
Eddy
17 FK8 CTR
