Super D ?
Super D ?
Who's considering running in Super D this year?
I haven't had time to look in detail, but I have a car that's restricted by the SCCA Improved Touring rules and is underpowered compared to many other cars in T50. Was wondering if Super D might be a bit more fun....
Re: Super D ?
My midget will be on track this summer. It is super D.
I did not make my final decision yet whether to keep my points together and run the miata in super D or run it in T40.
Rebecca
Rebecca
Re: Super D ?
Hi Jeff ---- I think I will be running my Elise in Super D this year. Then I don't have to worry about what I run for tires. Under the new rule I can also get into T50 but not with the Hoosier A6s I like to run. T60 with Hoosier A6. I should get extra points off for age. Anybody on Medicare should get an extra 10 points off
I also plan on using an Exige Cup Car but not at NHMS. I have run the numbers yet but I think it will make it into Super C class. The car is too low for NHMS or any rough track.
Re: Super D ?
Same problem as JW. I may run Super D.
But Jeff, we both beat the COM Lighting track record this weekend, on freezing cold, worn out tires...
Re: Super D ?
True, but the record was set when it was about 119 degrees. Not exactly power weather...6PAK72 wrote:Same problem as JW. I may run Super D.
Re: Super D ?
Just curious, but compared to what other cars in T50. I thought the BMW M is out of the class.is underpowered compared to many other cars in T50. Was wondering if Super D might be a bit more fun....
Re: Super D ?
Integra, and a certain Miata with a cam.paultg wrote:Just curious, but compared to what other cars in T50. I thought the BMW M is out of the class.is underpowered compared to many other cars in T50. Was wondering if Super D might be a bit more fun....
Re: Super D ?
Looked at the Super power/weight ratios and think we need a superE class. an ITA miata is no where near the the top of the Super D numbers.
Re: Super D ?
....conflicting requirements. If ITA compliance is more important etc...
I'm running an NC Miata at nearly 2700 pounds to be in T50 because I want to stay in the class so much.
Re: Super D ?
Hmm. I could always add 65-70 pounds of ballast and run in T40 on Nitto.
Except I'd be dead because Julie would kill me.
Re: Super D ?
Except Julie would kill me.TroyV wrote:You could do the same thing and run in T40.
Re: Super D ?
jeffw wrote:Hmm. I could always add 65-70 pounds of ballast and run in T40 on Nitto.
This is what I decided to do, but I don't need the ballast.
#01 T??
#01 T??
Re: Super D ?
Bill Hosselbarth is also going to run Super D, He is the one who suggested that I run Super D too, That way I wouldn't have to worry about what tires I run.
Troy, maybe you should try Super D
It's a lot less hassle than worrying about points.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Baidu [Spider] and 1 guest
