NHIS #2 results are up
rajito
Post by rajito » Fri Jul 07, 2006 8:27 pm
:ttiwwlt:
NHIS 2 results are up. Track records for North Oval configuration have been updated.
Also a message from the powers that be:
Powers that be wrote:A timing error has been discovered in the July NHIS results. Affected parties will be notified shortly. I apologize for the problem. Thank you for your understanding.
If you don't see the updated results / front page, hit the "Reload" (terrorists) or "Refresh" (infidels) button in your browser.
#66 SuperSlowGT
Silver 2004 Nissan 350Z
Post by Mick » Fri Jul 07, 2006 8:53 pm
You forgot to add "Oil slicks" to the track conditions note. :-s
boltonite
STGT lap times
Post by boltonite » Fri Jul 07, 2006 9:39 pm
Only 13/100 seconds between 2nd, 3rd, 4th, and 5th place in STGT!? :shock: That is amazing.
rajito
Re: STGT lap times
Post by rajito » Fri Jul 07, 2006 9:45 pm
boltonite wrote:Only 13/100 seconds between 2nd, 3rd, 4th, and 5th place in STGT!? :shock: That is amazing.
You're too kind to me. 2nd, 3rd, and 4th were separated by .034 (38/100th's) of a second.
I was DFL by over a second :)
I should add "Oil slicks and fire" to the track conditions.
#66 SuperSlowGT
ctkag
Post by ctkag » Fri Jul 07, 2006 10:17 pm
Disappointing to only beat my 2004 North Oval time by fractions of a second - with more hp & Hoosiers. Guess 'mooching' for a year didn't help my driving skills any. :(
-Keith-
SPB116
Post by DanDarcy » Sat Jul 08, 2006 10:22 am
You should also add gas to the track conditions.
On my second practice of the morning, my trunk filled up with gas and was coming out at a steady stream onto the track. I can't understand why they black flagged me. I wasn't on fire. (just kidding) :shock:
My battery and other electronics are in the trunk---if a spark ignited it, it would have been a BOOM not a fire :roll:
Post by offcamber09 » Sat Jul 08, 2006 1:27 pm
BTW, CONGRATULATIONS Dan on your first win! We know you got jipped in April.
Raj I'm with you- DFL- but I did spot my competitiors at least 200hp. It's too bad because the Mustang was hooked up handling-wise better than ever. Cross weighting really does work.
jadams
So what happened?
Post by jadams » Sat Jul 08, 2006 11:53 pm
Scott
What happened to your car anyway? I see that you TT's in the Rabbit. By the way, I just trailered my car back to my house. The rebuild is finally complete!!! :D It was quite a battle all the way, but seems like it should be pretty good. The alltime low point of the project was when frustration set in when the clutch was not working right after I fired it up for the first time. The car was on the lift, and I ended up putting it too high, and ended up smashing one of the T-Tops on the garage door opener! Oops. :oops: Glad it is all behind me now.
Joel Adams
1995 Pontiac Trans Am
Class T80
Re: So what happened?
Post by offcamber09 » Sun Jul 09, 2006 11:31 am
jadams wrote:Scott
T5 itis...popped out of third gear in the oval at full throttle- scrambled eggs after that.
The hits just keep coming with your car. Maybe time to lose the t-tops and tin over the roof ? That's high weight.
jadams
Post by jadams » Sun Jul 09, 2006 11:37 am
Yeah, I bet I could save about 40 lbs or so by getting rid of them. But it is just more work that I don't have time to do now. I will have to live with them for a little bit more. I got a new one at the junk yard, so it is all good now!
Joel Adams
Class T80
deimos
Re: NHIS #2 results are up
Post by deimos » Sun Jul 09, 2006 11:31 pm
rajito wrote: If you don't see the updated results / front page, hit the "Reload" (terrorists) or "Refresh" (infidels) button in your browser.
The COM webserver now forces expiry times on all pages. If your browser doesn't honor webserver expiry times, well, get a real web browser. Hint: IE doesn't honor webserver expiry times, just about every other browser does though.
This means that when you request the page, the browser should see the content expired weeks ago and actually get the new content from the webserver.
Andrew
'91 Sentra with wicked cool tint
Post by jlwhorf » Mon Jul 10, 2006 8:22 am
Scott I found this on my browsing. I know it is big bucks but it looks what you might need.
http://www.race-cars.com/boxsales/other ... 4346ss.htm
I am almost ready to fire my new engine, I have too come just about every obstacle I could imagine. It is almost ready to fire now. I am planning open track at NHIS on the 27th, WMC BMW in august. I may try Mosport in Sept, but I definately want to do NHIS3 and LRP with you guys.
Jonathan
Monte Carlo 900 PA
Post by offcamber09 » Mon Jul 10, 2006 11:06 am
Jonathan
Thanks Jonathan, the G force is the route I would go. The internals can be bought for under $2,000 and installed in a good v8 case- my own labor. Eventually that will be the solution. $3k for what he's got is what you would pay brand new from G Force- so no deal there.
Good luck with your motor.
-Scott
Monte Carlo 900 PA
rajito
Post by rajito » Mon Jul 10, 2006 1:13 pm
jlwhorf wrote:I am almost ready to fire my new engine, I have too come just about every obstacle I could imagine. It is almost ready to fire now.
No more fires, please!
#66 SuperSlowGT
eclip5e
Post by eclip5e » Mon Jul 10, 2006 4:51 pm
I'll be posting pics and videos and stuff later.
Ron. A
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
