2013 Licenses and NHMS Open Test
Brendan
Post by Brendan » Wed Apr 10, 2013 7:41 pm
So, car isn't quite ready to make it to our date this Friday, but I'm considering next Friday for one of NHMS' open test days if this weekend goes well in the garage. Never been to one before, but it says you need an active license. Have ours been printed out yet? Can they be mailed out, or can they be picked up if need be?
Guessing not, but anyone else considering next Friday's event?
Brendan
#04 SPC
White 1990 E30 M3
dradernh
Re: 2013 Licenses and NHMS Open Test
Post by dradernh » Wed Apr 10, 2013 8:50 pm
Brendan wrote:...anyone else considering next Friday's event?
Most definitely, esp. since this week's weather looks so unpleasant.
CP
Post by CP » Thu Apr 11, 2013 12:24 am
Brendan, next Friday's track-run test day will be filled with mostly SCCA racers, prior to the first regional race weekend. It's open passing, so be prepared for that. Think packs of swarming Miatas and anything goes. Stay below the blend line at track-out...they're anal about it, and watch you mirrors. You'll be running the south oval all day.
McMahonRacing
Post by McMahonRacing » Thu Apr 11, 2013 7:16 am
I PM'd Will a similar question yesterday but have yet to get a response, our thoughts were that I would like it in hand when I go to NASA Comp School on the 18th @ NJMP - Lightening and Dad is thinking he may like to try the LRP Test Day on I think the 23rd ...... maybe he will catch this post.
Brendan
Post by Brendan » Thu Apr 11, 2013 11:24 am
CP wrote:Brendan, next Friday's track-run test day will be filled with mostly SCCA racers, prior to the first regional race weekend. It's open passing, so be prepared for that. Think packs of swarming Miatas and anything goes. Stay below the blend line at track-out...they're anal about it, and watch you mirrors. You'll be running the south oval all day.
Thanks for the heads up. Not ideal, but better than no shakedown at all.
#04 SPC
White 1990 E30 M3
KKennedy717
Post by KKennedy717 » Thu Apr 11, 2013 11:37 am
Is the "open" test day run by NHMS or the SCCA? Is having an active COM license enough to qualify for participating in the "open" test day or do you need to have an active SCCA license to be able to run?
06 Mazda MX-5 #17
Post by Mick » Thu Apr 11, 2013 11:51 am
It's run by NHMS. Your COM license will get you in.
I'm not sure how they're running this one, but in the past you could purchase a full day, or opt to run 1/2 day. If I recall it was $100 for 1/2 day.
CP
Post by CP » Thu Apr 11, 2013 12:03 pm
The morning is usually empty, so you'll get the most open space then. Plus it's only an extra $50 for 4 sessions. The afternoon fills up quickly, and since it's the first test day of the season all the yahoos will be there.
Post by WillM » Thu Apr 11, 2013 5:21 pm
Licenses are not printed yet, sorry.
Production won't start before the week of the 22nd, but they should be ready by Summit.
PaddyMcP
Post by PaddyMcP » Thu Apr 11, 2013 9:58 pm
Brendan,
There are a few of us going to LRP next Friday. Reg is probably closed but it might be worth asking. Email me if you're interested.
boltonite
Post by boltonite » Fri Apr 12, 2013 6:17 am
Fyi, for a temporary license: login, My Profile > member #.
Brendan
Post by Brendan » Fri Apr 12, 2013 3:05 pm
PaddyMcP wrote:Brendan,
Thanks - probably better for me to shoot for NHMS, because I won't know if I'm ready until Sunday or Monday. (Car's pretty close, but have a couple key things I need to get done this weekend before I can commit to anything.)
The other thing about LRP - my car wouldn't make sound as is, if the limitations are in effect that day... Need to worry about that before Tremblant too, but not happening this weekend.
#04 SPC
White 1990 E30 M3
Aricracer
Post by Aricracer » Fri Apr 12, 2013 9:20 pm
Clicking on: My Profile > member # sent me to an error page. Should someone know about this?
-Aric
1997 Ford Mustang SVT Cobra ITE/SB
1986 Pontiac Fiero GT
hroundy
Post by hroundy » Sat Apr 13, 2013 8:50 pm
It displayed my license in a separate tab. Do you have popups blocked?
Aricracer
Post by Aricracer » Sat Apr 13, 2013 10:25 pm
Error in separate window/tab:
Server Error in '/comscc' Application.
Index and length must refer to a location within the string.
Parameter name: length
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Source Error:
Line 81: if (mp.LastName != null && mp.MembershipStatus == "Active")
Line 82: {
Line 83: yrIssued = mp.COMLicenseNum.ToString().Substring(0, 2);
Line 84: if (Convert.ToInt16(yrIssued) > 60)
Line 85: {
Source File: d:\hosting\5677599\html\comscc\License.aspx.cs Line: 83
Stack Trace:
[ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Parameter name: length]
System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) +7495739
System.String.Substring(Int32 startIndex, Int32 length) +11
License.Page_Load(Object sender, EventArgs e) in d:\hosting\5677599\html\comscc\License.aspx.cs:83
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
-Aric
