Guess I'll start a T80 rollcall
savage217
Post by savage217 » Tue Apr 02, 2013 10:47 am
Who is in T80? I plan on running my m3 on street tires in this class. Any challengers? :wink:
Nick DeRosa #305
Re: Guess I'll start a T80 rollcall
Post by eastcoastbumps » Wed Apr 03, 2013 10:26 pm
I'm in T80 with points to spare on RA1's with the black S2000.
Post by StephanAlfa » Thu Apr 04, 2013 3:11 pm
I am just starting a betting pool ... :P :lol: :lol: :lol:
Post by Chrispy » Thu Apr 04, 2013 4:29 pm
I'll be in T80 on a DOT race tire, dropping the width down to a 275, which might actually make it faster in TT trim.
Actually I wont be in anything unless I get cracking and get the car ready.
savage217
Post by savage217 » Fri Apr 05, 2013 11:51 am
Wow Chris,
I am suprised you were able to fit in that class. I feel like my car is still inferior. Almost worth adding some weight to run a Hoosier or something. I can't decide which way to go.
Nick DeRosa #305
Post by Mark Swinehart » Fri Apr 05, 2013 12:13 pm
He helped write the rules!
blindsidefive0
Post by blindsidefive0 » Fri Apr 05, 2013 12:18 pm
savage217 wrote:I feel like my car is still inferior.
Racing excuses, level 10: pre-excuses...before the race has even begun.
Nick, I've talked to both you and Chris about your cars - I'm excited to see how the match-up shakes out.
savage217
Post by savage217 » Fri Apr 05, 2013 1:06 pm
Well it depends what he did to fit it into T80. I mean if weight were added or mods were taken off, etc, than of course T80 sounds like a fine class to fit into. However, If all that was changed were his tire size from (335 to 275), I would like to see the classification sheet for mods. I am not starting anything, I am just curious and because I am competitive it is only natural for me to respond this way.
Nick DeRosa #305
blindsidefive0
Post by blindsidefive0 » Fri Apr 05, 2013 1:15 pm
savage217 wrote:I would like to see the classification sheet for mods.
This is legit. We just talked about this at the scrutineers' meeting. We plan to make available all classing sheets for the event for any competitor to come around and check it out.
Post by Chrispy » Fri Apr 05, 2013 4:11 pm
Yes, sheets will be posted, it helps keep everyone honest.
In all fairness though my car doesn't have a lot of mods and starts as a mid T70 car. I take the biggest points hit for suspension due to right height adjustable springs, 2-way shocks with piggyback, and sway bars (total 8 points). Brake upgrade (2 points), tires 7 points, engine mods using dyno method (~2 points), weight is about 180 over so -4 points. Grand total, 89 ish. If I was building from the ground up to fit the rules I would do things a little differently there which would give back a couple of extra points without a performance penalty.
Post by Chrispy » Fri Apr 05, 2013 4:14 pm
savage217 wrote:Wow Chris,
It's a tough call. Lighter is faster, but grip is king on the tight tracks like NHMS.
Post by TroyV » Fri Apr 05, 2013 4:25 pm
Nick... Chris pulled what was formerly known as a "Darcy" to see to it that he could fit in T80.
Post by DanDarcy » Fri Apr 05, 2013 8:42 pm
Troy---- with my changes ---- I've Darrcyized my Lotus ------ I'll be running T50
Post by DanDarcy » Fri Apr 05, 2013 8:44 pm
Or I might decide to use my Porsche 996 twin turbo , It is a T80 class car.
CP
Post by CP » Fri Apr 05, 2013 9:32 pm
Dan, run the plane in the Air60 class or a suped up tractor in Dirt30...or that Italian that you keep under a cover.
