Coming back to comscc after a difficult 2011
Neptune441
Re: Coming back to comscc after a difficult 2011
Post by Neptune441 » Wed Oct 17, 2012 8:33 pm
Car was dyno'd down in Kingston NH on Dyno Jet at 394 who/ 360wtq we were limited by the wastegate spring, So Now I will change the waste gate spring and then see what happens. Should be closer to 450 maybe more on 93 but have to see where the EGT's take us. Also see VP Racing fuel for 100 octane *Maybe* It's 268.00 for 15 gallons Which I'd probably only run on TT day anyway. :roll:
Neptune441 wrote:
962porsche wrote:after missing the 2011 and the 2012 season your just going to blow the motor sky high any way !
o-crap did i say that out loud ?
See, You never curse someone , because you never know what's around the corner :lol: [
quote="962porsche"]at the least i'm making more more thru every event so i am making head way with the drive line issues . it's not the chains any more it's now in the rollers of the chain tensioner . so some day i will get this car up to speed with out things braking .
it would be good to see you at the nhms 4 event . did you ever get signed off for your comp license with comscc ?
I really wanted to make it to that event but how the tuning fell I was short one day. I'd like to David but we shall see nothing is ever set in concrete.
Adrian
Post by 962porsche » Thu Oct 18, 2012 12:11 am
it sucks you missed this season too ! i hope to see you at some events next season ?
with my car i'm really getting down about it !
i have been chasing one fix after another . its started with clutches i bought the car knowing that thats why i got the car cheap . but then it went to eating chains i fix that then it's the chain tensioner . from there it's the rollers on the chain tensioner . now it seams the gear box will be the trubble .
last night i started building two chassis for the car one is just a new back half using the same type of motor but a deferent lay out . turning the motor in the chassis the way it sits in a motorcycle .
the other is a all new chassis front to rear using the porsche boxter S motor , trans and suspension . i'm building the tub out of aluminum using a honeycomb design like the porsche 962's used . years ago i restored a 962 and took all the tub measurments then so it was ez for me to change the design to get the boxter suspension to bolt up to the 962 tub . at my best guess is the car with the boxter parts will weight in at the high 1200 LBS low 1300 LBS range with 290 HP .
Neptune441
Pearl lives with fresh turbo
Post by Neptune441 » Sat Mar 16, 2013 3:00 pm
Well After a blown AMR T60R making 408whp 350 torque DynoJet numbers... The center bearing walked completely out of the turbo leaving about 1/2 engine oil in the downpipe/CBE ( That was a royal PITA :evil: I had some suspicions coming back from the tuning and even the tuner said the turbo didn't sound right.. sure enough later that week boom.. bye bye Turbo. Now very happy with the turbo I have in there now and went down to see EFI Logics a few weeks ago and here's the results.
Adrian
Post by 962porsche » Sat Mar 16, 2013 8:31 pm
so you missed the last two years are you going to do any events this year ?
Neptune441
Post by Neptune441 » Sun Mar 17, 2013 7:08 pm
Just gathering a few last parts to make it track ready. Very close now.
Adrian
Neptune441
Post by Neptune441 » Sun Mar 17, 2013 7:12 pm
962porsche wrote:so you missed the last two years are you going to do any events this year ?
Can't just use a company credit card to fund my hobby :wink: lol
Adrian
Post by 962porsche » Mon Mar 18, 2013 1:00 am
why not i do ! and now thanks to Mark i'm even going to right off the cost of the events also .
Neptune441
Post by Neptune441 » Mon Mar 18, 2013 8:25 pm
I was just razin ya. Yes David I plan on making a few, I had a nice chat with Ted this afternoon too.
Adrian
Post by 962porsche » Mon Mar 18, 2013 11:09 pm
sorry i missed you call i was buying a crap load of miata stuff .
i will give you a call tomorrow (tuesday)
Neptune441
Post by Neptune441 » Fri Mar 14, 2014 8:34 pm
Oh Well , awaking from the dead I suppose, I've had one pitfall after another but .. I now have a car that is ready. I switched the set up and went fully rotated Image I went down to EFI Jan 4th the frigin coldest day of the year -12 degrees and have an AEM Fuel Pressure regulator set with a smaller orifice and as they wanted to crank pressure up to 52psi the system saw that and said I don't think so... and sent back pressure through the crankcase right to the turbo seal and destroyed the seal. Luckily it was not catastrophic but you could tell it was not good. Then came the decision to upgrade the turbo and injectors and new fuel pressure regulator(Aeromotive). As it stands right now I am giving 2014 a green light! On a side note I have learned that shell racing fuel has pulled out of the US, but is continuing to make racing fuel under a new name called "FUSE" which is unleaded as high as 116octane and as low as 105.
Adrian
jvangelder
Post by jvangelder » Sat Mar 15, 2014 1:29 pm
While I only have 1 comscc event under my belt, it will be nice to see another sti there. Are you going to nhms-1? Ill be there in an 05 white sti on stock gold wheels, just look for the guy who looks lost, thats me
Neptune441
Post by Neptune441 » Sun Mar 16, 2014 8:09 pm
Well this will be my first time out in my STI , but not my first rodeo as I've had a speed3. I've been given some advice from Ted who is a owner of a 06-07 STI with FPRed "Like" turbo on the track set up. I'm happy over all. Good to see another subaru member as well. I met a few last race in October ( Were you parked in the corner near the apex of T12? If so I believe I met you.
Adrian
nhsilversti
Post by nhsilversti » Thu Mar 20, 2014 12:02 am
i have a fp red not one "like" it :wink:
i doubt ill make the first event this year by i have plans to make at least a couple events.
Neptune441
Post by Neptune441 » Sun Mar 23, 2014 11:27 am
nhsilversti wrote:i have a fp red not one "like" it :wink:
Always have to keep it a mystery Ted ;-) Glad to hear you'll be at a few events
Adrian
