Video cameras
Video cameras
Post by eastcoastbumps » Sun Jul 22, 2012 5:46 pm
Just curious what everyone is using for video cameras. I only found old threads on the subject. Paddy and I just bought a data logger and its supported by Trackvision to do data overlay. GoPro seem to be the most popular.
cfossum
Re: Video cameras
Post by cfossum » Sun Jul 22, 2012 7:06 pm
GoPro
works fine, wish it had a remote.
dradernh
Re: Video cameras
Post by dradernh » Sun Jul 22, 2012 8:48 pm
Panasonic HDC-SD9 3CCD HD Camcorder for in-car-looking-out & GoPro Standard Definition Non-Wide Angle for attaching to the outside of the car. They both do a good job.
n1gzd
Re: Video cameras
Post by n1gzd » Sun Jul 22, 2012 9:47 pm
i have been usimg my iphone mounted inside the car at the base of the windshield.
rebecca
Brendan
Re: Video cameras
Post by Brendan » Sun Jul 22, 2012 10:15 pm
I have a GoPro, but have heard some good things about these:
http://replayxd.com/cameras/replay-xd1080-camera/
The newest version of the GoPro does have a WiFi remote as an add-on
#04 SPC
White 1990 E30 M3
ST1Ddope
Re: Video cameras
Post by ST1Ddope » Sun Jul 22, 2012 10:17 pm
I use a gopro hd mounted to the rear cage, It works well if you put rubber around the bar to soften the vibration. For the video and data overlay software I would suggest race render, it is dirt cheap ($35) and full of features.
Chad Fox #9
1996 Integra GS-R T50
CP
Re: Video cameras
Post by CP » Sun Jul 22, 2012 10:58 pm
cfossum wrote:GoPro
It does but you have to pony up for the Traqmate Traqdash setup. The GoPro starts recording as soon as you begin to log data via the touchscreen.
Re: Video cameras
Post by John F » Mon Jul 23, 2012 7:55 am
Brendan wrote:I have a GoPro, but have heard some good things about these:
The Wi-Fi remote works for both versions of the GoPro
http://gopro.com/hd-hero-accessories/wi ... ote-combo/
Re: Video cameras
Post by StephanAlfa » Mon Jul 23, 2012 8:30 am
I have two GoPros:
A std one and an HD one. THe HD allows me to program resolution form the inside and shoot out when it's bright and "balances" both in/out.
There is a remote version now (Will has one I think) as that helps you turn the thing on and off "on demand" and helps when you are all strapped up and the button is not within reach.
naschmitz
Re: Video cameras
Post by naschmitz » Mon Jul 23, 2012 9:50 am
John F wrote:The Wi-Fi remote works for both versions of the GoPro
That looks pretty slick.
Bert Schmitz
Re: Video cameras
Post by WillM » Mon Jul 23, 2012 5:28 pm
I have a GoProHD (the original HD version, not the new "HD2" version) with the wifi bacpak. It works as advertised.
I had a frustratingly hard time updating the firmware, but once I was able to get all three of the modules updated (the camera, the remote, and the bacpak), it all just worked.
The biggest problem with the bacpak is that you'll now have 3 things to charge:
1. The camera
2. The bacpac
3. The remote.
The remote has complete control over the camera, including turning the camera off and on, and that in a way is the problem. It is easy to shut down with the remote, but that only turns off the camera and the remote, not the bacpak. It doesn't take long to drain down the bacpak if you forget to turn it off manually (via an easy to access push button).
Still, it is worth it and makes the GoPro that much more user friendly. Live streaming to your smartphone to preview the image will be a huge win, if it works right when it is released.
naschmitz
Re: Video cameras
Post by naschmitz » Mon Jul 23, 2012 8:43 pm
Sounds like my Vio POV HD hardwired into +12V with the RF remote is still worth the exta bucks then.
Bert Schmitz
Re: Video cameras
Post by paultg » Tue Jul 24, 2012 12:36 pm
This is what I'm using with an IO Port mount:
http://www.2fidelity.com/Camcorders/HD/GVS/features/
720p at 60 frames per second. I use a 32gb SD card and an external mic tucked into the seat pocket on the passenger side to keep wind noise down. Works pretty good and has a remote. Plus it was like $100 I think when I picked up it, so I don't worry about it breaking or getting beat up. I pretty much just use it for autox and track days. - Paul G.
Re: Video cameras
Post by Stynger » Wed Jul 25, 2012 11:45 am
The camera and bacpak have to be on all the time for the Wi Fi to work. Use a vented case it can get quite warm.
When the bacpak drains down it pulls power from the camera battery.
I cut a hole in my GoPro case so I can hook the USB charge cable to a 12v charger off the car power port and keep the camera charged thus keeping the bacpak working. :wink:
Re: Video cameras
Post by brucesallen » Wed Jul 25, 2012 11:51 am
I have two GoPro. Too bad they look so dorky.
