I've got a lightly used set of Stoptech ST40 calipers that each have a stripped bleeder hole (there are two bleeders per caliper). I think the holes could be tapped and a larger bleeder screw installed to be safely functional again. The piston bores are staggered and designed to work for a 1G DSM or Galant VR4 with a stock master cylinder (5/8" iirc but it's been a while). They take a standard Porsche brake pad and have a removable structural rib that makes pad changes a snap. I was going to dump these at the scrap yard in a few weeks (they cost $500 each new) but thought that I'd see if anyone wants a small project over the winter.
Email me at cypeake at hotmail dot com if interested. I'm in Norfolk, Mass.
Two Stoptech ST40 4-piston brake calipers: GONE
Re: Two Stoptech ST40 4-piston brake calipers: free
Hand-off pending...
Re: Two Stoptech ST40 4-piston brake calipers: GONE
Gone.
