hurricane ????
nateh
Re: hurricane ????
Post by nateh » Sun Aug 28, 2011 11:23 pm
We didn't get much wind, but we did get a hell of a lot of water. Roads are impassable - flooded and/or washed out - in all directions. Lots of bridges down too.
I probably won't make it tomorrow. Hoping for Tuesday.
nateh
Re: hurricane ????
Post by nateh » Mon Aug 29, 2011 12:14 am
Here's the road I usually drive to get to work. Also to get to the track. Or pretty much anywhere.
Re: hurricane ????
Post by dinoracer » Mon Aug 29, 2011 12:54 pm
Gee Nate, Can't imagine why you wouldn't want to pull the trailer down that road....
Glad you're OK, good luck getting thru the mess!
Re: hurricane ????
Post by 962porsche » Mon Aug 29, 2011 10:10 pm
nate did i thank you for the offer to stay at your place sunday night ? the road is only washed out to the yellow line so half the road is still there . sam thanks for the info on the track closing on sunday . i went up there and the gate was locked and all the lights were off at the sign in building . so here my story the rain started saturday morning about 9 AM by saturday night it was getting heaver then by 2 AM sunday the hurricane got to us . it was a cat 1 that lasted to about 2 PM . by 4 there was a little sun starting to show but it was still windy . i took off for nhms about 6 pm got there about 9:30 1/4 of 10 . did some laps monday and cooked another chain on the diasio . if i take it ez the chain does not over heat but when i push the chain over heats . i took the temps of the chain and it was 307 F. degrees . when i take it ez and don't push with lap times around 1:21 the chain temp is 240 F. for those people that don't know the diasio uses a motorcycle motor with a chain drive to a winters quick change rear axle . i get one track day out of a chain at 120 dollars per chain . two days at the track 240 dollars for chains . the joy to run with comscc priceless !
nateh
Re: hurricane ????
Post by nateh » Tue Aug 30, 2011 8:20 pm
David -
Just as well you didn't take my up on the offer, since I missed day 1. Day 2 was fun, though!
That video was early in the proceedings. Later on it washed out the rest of the way. But the back way was opened to 4WD by a neighbor with a dozer, so I sneaked out.
Lots of VT flood photos here: https://www.facebook.com/media/set/?set ... 871&type=1
Sorry to hear about the chain problems. I hope you can figure out why it's overheating.
Re: hurricane ????
Post by 962porsche » Wed Aug 31, 2011 9:12 am
good god nate i had no idea the storm hit VT that hard .
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Baidu [Spider], Bing [Bot] and 1 guest
