My DNF During the Relay
Dtangard
Post by Dtangard » Thu Jul 14, 2011 10:33 pm
I pulled the transmission tonight and found out my clutch disk disintegrated into a fine powder. Has this happened to anyone else before? I'm using the mazdamotorsports heavy duty pressure plate and an oem disk.
I have pictures but they are too big for the forum..
#01 T??
escortracer
Re: My DNF During the Relay
Post by escortracer » Fri Jul 15, 2011 6:01 am
You can down size the pic at photo bucket.
I had the same thing happen to my OEM that came with the car had a lot of miles on it. Better the clutch than the trans.
T4 268
Post by TroyV » Fri Jul 15, 2011 8:27 am
Wow. How old are those parts Derek?
BTW: smart move getting off the track....It kept the relay moving. I first thought you had run out of gas as we had talked about earlier.
Dtangard
Post by Dtangard » Fri Jul 15, 2011 9:43 am
It was a brand new clutch actually. I'll downsize the pictures when I get home from work. I couldn't believe all that was left was a fine powder.
#01 T??
Post by TroyV » Fri Jul 15, 2011 10:08 am
You must have been driving flat out. :)
CP
Post by CP » Sat Jul 16, 2011 12:12 pm
Move to an ACT unsprung 4-puck disc. I use this with a stock pressure plate (for SM racing) and it holds well and could be streetable.
Dtangard
Post by Dtangard » Sun Jul 17, 2011 2:37 pm
Hi Cy. I ordered an ACT sprung 4 puck disk because I thought it would be a little less abusive on my transmission.
#01 T??
CP
Post by CP » Tue Jul 19, 2011 10:16 am
Either one will hold up better than a stock disc, as well as stay cooler due to the puck design. Just don't plan on slipping it much to get the car moving. Torque the pressure plate bolts to spec (I think it's around 22ft/#).
Dtangard
Post by Dtangard » Thu Jul 21, 2011 10:17 pm
Thanks Cy
#01 T??
Dtangard
Post by Dtangard » Fri Jul 22, 2011 10:53 pm
Does anyone have a clutch tool for a miata? Can I just pick one up at a local parts store?
#01 T??
imgon
Post by imgon » Sun Jul 24, 2011 7:55 am
Are you talking about the alignment tool? If so the new clutch typically comes with it, all the ones I have bougght had one, its just a piece of plastic you slide into the flywheel. Good luck.
Chuck
'19 Mustang Bullitt
#749
Dtangard
Post by Dtangard » Sun Jul 24, 2011 7:27 pm
Unfortunately this didn't come with one. I'm going to do measurements to line it up.
#01 T??
Users browsing this forum: Amazon [Bot], Google [Bot], Semrush [Bot] and 1 guest
