SP harness rules
Dave_G
SP harness rules
Post by Dave_G » Mon Jun 28, 2010 10:10 pm
I remember a couple years ago when the SP safety rules were changed so that, among other things, the harness/belt rules were the same as for SS/ST (viewtopic.php?f=8&t=1643). Supposedly this was done to lower the barrier of entry for people with small mods that put them in SP. I just heard from a prospective new member that he probably won't do COM events because his supercharger pulley puts him in SP, and he would need to install a harness bar and harness in order to run. I was remembering the discussion from a couple years ago and didn't think that was right, so I looked it up. In the current rules, it seems he is in fact right:
VI.F.2: SS and ST cars may use any DOT, SFI, or FIA approved harness. All other cars must
use an SFI or FIA approved harness with a minimum of 5 points
Did this get changed back and I just missed the discussion?
ST4 Miata #62
Re: SP harness rules
Post by jlwhorf » Tue Jun 29, 2010 11:01 am
Dave,
There was a typo in the first revision of the 2010 rule book omitting SP from the list, and I believe it was fixed in the newest version. In short, SP cars can use OEM and other DOT harnesses.
Dave_G
Post by Dave_G » Tue Jun 29, 2010 11:27 am
Thanks for the clarification. The online version of the rule book on the web page still just shows SS and ST. Since that's the one people are likely to check, it should probably be updated if it's out of date.
ST4 Miata #62
DaveVT189
Post by DaveVT189 » Tue Jun 29, 2010 3:59 pm
I also thank you for the clarification; I'm the guy Dave_G was referring to (we're both members of the Sports Car Club of Vermont). For the record, I have a 2002 MINI Cooper S with a 15%-reduction supercharger pulley (+ CAI, Springs and rear sway bar), thus the question.
I (now) look forward to attending an event w/ you soon ...
