Fender roller for Monticello
jimmacsrx7
Hi, anyone have a fender roller that they can bring to Monticello? I have some new to me wider race tires and they look pretty damn close. Thanks.
Jim McNamara
___________________
#30 PA Mazda RX7
Jim McNamara
___________________
#30 PA Mazda RX7
Re: Fender roller for Monticello
A baseball bat works well. Seriously. The varying diameters are handy.
-Carl
-Carl
jimmacsrx7
I have heard that as well Karl.We shall see.
or a broom handle, depending on how much clearance you have.
If you are not big on aesthetics, vise grips work.
sawzall's work great too
They do!
I used a roller on my front fenders this weekend and it took all of one minute per side. I got into a guy (well, he got into me
) a few weeks ago at the end of a national race, had a fender slightly pushed in and ruined the tire between turns 9 and pit-in at NHMS.
If you have paint that you care about you may want to use a heat gun or hair drier to soften the paint as you roll so it doesn't chip.
3 lb hammer rolled/flared my fenders fine
- Paint looks like hell, but whatever, Race Cars don't have to be pretty.... right?
Subaru 25RS
bigbrakeparts
It took a good 3 hours to do the fender rolling on the WRX. Finally fit a 275-40-17 all around, but had to roll/pull the fender a good 1 to 1.5 inches out back.
I used a real fender roller ( don't remember the brand), and the paint chipped, so I just masked it off and painted it with some grill paint. I would highly recommend the actual tool.
Works well!
-G
Works well!
-G
Oooooops! Gary "pulling out the fenders 1 to 1.5 inches" bumps your car into class PB. The problem is, PB requires a roll bar and 5 point or better restraint system.bigbrakeparts wrote:It took a good 3 hours to do the fender rolling on the WRX. Finally fit a 275-40-17 all around, but had to roll/pull the fender a good 1 to 1.5 inches out back.
Works well!
-G
bigbrakeparts
PB is definitely my new home! Just look under the hood!
Rollbar... check
6 point harness ... check
crappy driver at the wheel ... check
What can possibly go wrong!
-G
Rollbar... check
-G
Go for it!bigbrakeparts wrote:PB is definitely my new home! Just look under the hood!
Rollbar... check
-G
