Time for an inspection sticker :/
Post by Mick » Tue Mar 07, 2006 4:41 pm
The inspection sticker on my car expires this month and I have some questions about MA state inspections.
The car is pretty much a dedicated track car but I need to keep it registered for at least 1 more season. Currently all accessories work, lights, horn, wipers ect... and it should pass smog with out a problem. The part I'm not sure about is the seats, harnesses and roll bar.
In the front I have a pair of Cobra fixed back seats with 6 point harnesses, the factory belts have been removed. The rear seat has been removed along with the belts and in it's place is a bolt in roll bar, the cross section is removable.
Can anyone tell me what the minimum I need to pass would be?
Does the rear seat really need to be there along with the belts?
I think the front seats will pass, but what about the cam lock 6 point harnesses?
Thanks
mhiggins
Post by mhiggins » Tue Mar 07, 2006 5:13 pm
You should be able to pass with the roll bar in and no back seat. I would install the front factory belts, driver and passenger side and take out the harnesses for inspection. Also run the car for ½ hr some highway some back roads. Put some tires DOT with good meat on them. The worst thing you will get a reject sticker that is good for a month and they should tell you what to change to pass.
Mike
enjoythemusic
Post by enjoythemusic » Tue Mar 07, 2006 5:59 pm
That is great news if you are sure roll bars are lgal. Want to add a proper Halon system (that is fine) but the roll bars, i have heard, are not OK in NH. Spoke with a upper ranked guy in the NH police dept about it. Anyone know if bars are ok for NH?
FYI Mike: the only harness setup i know that is DOT legal in the United States is the Schroth Profi-asmII, and that is what i use. Think all it really is, besides the usual DOT certification hoops, is that the buckle has the orange colored PUSH button versus a black lever. Hope this helps.
Enjoy the Track,
Steven R.
http://www.EnjoyTheTrack.com
BrakeL8r
Post by BrakeL8r » Wed Mar 08, 2006 11:00 am
enjoythemusic wrote:[Rollbars, I] have heard, are not OK in NH. Spoke with a upper ranked guy in the NH police dept about it. Anyone know if bars are ok for NH?
Roll BARS are definitely legal in NH. I have one in my Mustang convertible. Roll CAGES may be a different story. I can only speak from experience.
--Michael
ST4 Miata #176
mhiggins
Post by mhiggins » Wed Mar 08, 2006 11:15 am
I have owned three street / track racecars (SSGT-SPA) registered, inspected and driven daily in MA. One with a 4 point bar, the others having 6 point+ cages with aluminum butler built racing seats and five point harnesses and just door panels. They still checked to see if the factory seat belts were installed in the front, most of the time. I’m sure the cobra seats are OK. Need to have the air bag in as well, if your car came with one. Being in ST2 your interior is still almost all there. I would put the factory belts in, if you still have them for the inspection. If you get rejected you 60 days to comply not 30. Just to be clear.
Mike
SSNH
Post by SSNH » Wed Mar 08, 2006 11:24 am
http://mass.gov/rmv/faq/inspection.htm#25
What do they inspect on my vehicle?
VIN Number/Registration/License Plates
Windshield
Wipers/Windshield Washer
Headlights/Headlight Aim
Turn Signals/4-Way Flashers
Tail Lamps/Brake Lights/Backup Lights/Other Lighting Devices
Horn
Exhaust System
Tires
Body Panels/Fuel Tank
Service Brake
Parking/Emergency Brake
Seat Belts
Ball Joints/Steering/Suspension
Emissions Test/Emissions Components (if applicable)
Post by Mick » Wed Mar 08, 2006 11:25 am
I still have the factory belts, but will need to install the factory seats to have them functioning properly.... If I'm going that far I may as well take the center section out of the roll bar and throw the rear seat back in. Fun!
Not a big deal, I was just hoping I could save myself the trouble.
mhiggins
Post by mhiggins » Wed Mar 08, 2006 12:19 pm
Mick wrote:Thanks,
If it’s not a daily driver try getting it inspected before you do the work.
mike
swinecanfly
Post by swinecanfly » Wed Mar 08, 2006 4:56 pm
Mike:
How are you gonna anchor the belts to the B pillar with the roll bar in?
Craig
sdcham1
Post by sdcham1 » Wed Mar 08, 2006 6:41 pm
Please note that I owned and drove 1993 Mustang Cobra with a full cage for 5 years on the street with no issues. I really don't think that the tech at the inspection station is really going to care. If anything they may think that the car is really cool. In addition I still had the factory belts attached. You may want to just try to get it inspected first before doing all that work.
Post by Mick » Wed Mar 08, 2006 7:03 pm
Craig,
The front belts are still in the car, there's just enough room for them to clear the roll bar.
sdcham1
Was your rear seat present? ..or did you just have the rear belts and no rear seats?
sdcham1
Post by sdcham1 » Wed Mar 08, 2006 7:06 pm
The rear seats were out
Post by Mick » Wed Mar 08, 2006 7:12 pm
Oh, well that's promising. I'll give it a try without going back to stock. Like you guys said, worst case I get a rejection and go back later with the stock stuff in place.
Post by offcamber09 » Wed Mar 08, 2006 8:13 pm
Mike, give me a call if you want it to pass as is. We don't do them, but I can get it done...you didn't hear that from me.
Post by Mick » Wed Mar 08, 2006 8:42 pm
offcamber09 wrote:Mike, give me a call if you want it to pass as is. We don't do them, but I can get it done...you didn't hear that from me.
I'll give you a ring :wink:
Thanks
