FS: Spec Miata
doc2s
FS: Spec Miata
Post by doc2s » Sun Dec 20, 2009 10:43 am
For Sale:3rd in SCCA Race at NHMS 5/09
Best Offer
2001 Spec Miata, Silver
Top SCCA finisher, finished 3rd at NHMS May 2008, 5th at Lightning NJMP July 2008.
Built in 2008 from a street car donor with no accident history, no rust, with 40k miles.
Cage with NASCAR double bars on both sides by DWW Motorsports.
Original street motor with 41000miles. (about 1k miles, track).
Schroth Profi II-6 HANS harness, black.
Team Dynamics Pro Race 1.2 Black Wheels
1 Extra set of black Team Dynamics Pro Race 1.2 Wheels.
Cobra Sebring S Seat with high-side containment, HANS compatibility.
Fire extinguisher.
Heavy duty Aluminum radiator.
Momo Mod80 steering wheel with radio buttons.
Hard wired AMB transponder.
ACT clutch.
SCCA logbook
Kill switch, roll bar mounted.
Front and rear two hooks.
Safecraft Right Side Net.
Window net.
Wide angle rear view mirror
Roll bar padding.
Car weighs 2200 with no fuel, driver, or ballast.
Contact: Osamah El Rifai, osamah@mit.edu. Car is located in MA.
Re: FS: Spec Miata
Post by Mark Swinehart » Sun Dec 20, 2009 11:59 am
What are you asking? $$$$?
doc2s
Re: FS: Spec Miata
Post by doc2s » Sun Dec 20, 2009 2:17 pm
14k
Re: FS: Spec Miata
Post by Stynger » Mon Dec 21, 2009 5:02 pm
What suspension?
doc2s
Re: FS: Spec Miata
Post by doc2s » Mon Dec 21, 2009 6:43 pm
sm spec suspension
CP
Re: FS: Spec Miata
Post by CP » Thu Dec 24, 2009 1:23 pm
This is a sorted, fast car built by one of the premier local SM shops. You couldn't build this car for what he's asking. The buyer should use it for COM events because I don't want to race against it in SCCA next season :)
doc2s
Re: FS: Spec Miata
Post by doc2s » Wed Dec 30, 2009 3:48 pm
thanks cy. hope all is well with you.
