For Sale:3rd in SCCA Race at NHMS 5/09
Best Offer
2001 Spec Miata, Silver
Top SCCA finisher, finished 3rd at NHMS May 2008, 5th at Lightning NJMP July 2008.
Built in 2008 from a street car donor with no accident history, no rust, with 40k miles.
Cage with NASCAR double bars on both sides by DWW Motorsports.
Original street motor with 41000miles. (about 1k miles, track).
Schroth Profi II-6 HANS harness, black.
Team Dynamics Pro Race 1.2 Black Wheels
1 Extra set of black Team Dynamics Pro Race 1.2 Wheels.
Cobra Sebring S Seat with high-side containment, HANS compatibility.
Fire extinguisher.
Heavy duty Aluminum radiator.
Momo Mod80 steering wheel with radio buttons.
Hard wired AMB transponder.
ACT clutch.
SCCA logbook
Kill switch, roll bar mounted.
Front and rear two hooks.
Safecraft Right Side Net.
Window net.
Wide angle rear view mirror
Roll bar padding.
Car weighs 2200 with no fuel, driver, or ballast.
Contact: Osamah El Rifai, osamah@mit.edu. Car is located in MA.
FS: Spec Miata
FS: Spec Miata
- 22.JPG (60 KiB) Viewed 8970 times
Re: FS: Spec Miata
What are you asking? $$$$?
Re: FS: Spec Miata
What suspension?
Re: FS: Spec Miata
sm spec suspension
Re: FS: Spec Miata
This is a sorted, fast car built by one of the premier local SM shops. You couldn't build this car for what he's asking. The buyer should use it for COM events because I don't want to race against it in SCCA next season
Re: FS: Spec Miata
thanks cy. hope all is well with you.
