Braille Batteries
cuda6666
Braille Batteries
Post by cuda6666 » Fri May 08, 2009 12:34 pm
Anyone have experience with them? Product description says they must be charged with an "AGM" battery charger. Are these different from the typical battery charger, and are they hard to find in your typical gas station/repair shop?
Thanks
Re: Braille Batteries
Post by DanB » Fri May 08, 2009 1:47 pm
I charge my 26Ah Hawker Genesis AGM battery with a regular 10-amp charger. No problems, except when I leave the battery connected over the Winter, and when the voltage drops below a threshold the headlight relays CLOSE and power up the lights, sealing the $150 battery's doom. I should fix that...
zip4zat
Post by zip4zat » Fri May 08, 2009 1:49 pm
I have one, i cant remember if its the 6lb or 10lb variety. it works fine, though if the car sits for a long period of time the battery has a hard time turning things over. so I just keep it on a trickle charger when its collecting dust. Ive heard that these types of batteries go bad (chemically)if they dont stay charged.
as for charger, I have an el cheapo sears charger that fits the bill per the instructions (yes I actually read it)
cuda6666
Post by cuda6666 » Fri May 08, 2009 2:02 pm
I was planning on removing it between events.
Post by breakaway500 » Fri May 08, 2009 2:39 pm
My Atoms use Braille batteries and I have charged them with a Battery tender many times with no ill effects. I have a Braille in the Focus and also use a BatteryTender to keep it topped off. I think they (Braille) are mostly worried about forcing too much amperage in the battery too quickly. Any trickle charger around 1amp/hr. should be fine.
Post by TroyV » Fri May 08, 2009 2:57 pm
Yeah folks....you read that right... Atoms
cuda6666
Post by cuda6666 » Fri May 08, 2009 3:03 pm
TroyV wrote:Yeah folks....you read that right... Atoms
That's a kind of running shoe, right? One for each foot.
Post by breakaway500 » Fri May 08, 2009 3:39 pm
Just more toys to break,Troy. :lol:
zip4zat
Post by zip4zat » Fri May 08, 2009 3:58 pm
cuda6666 wrote:I was planning on removing it between events.
yeah, I disconnect it over teh winter, but I hate having to reset my clock between events. :roll:
cuda6666
Post by cuda6666 » Fri May 08, 2009 5:06 pm
Not to mention reloading the Real-Time MAP.
Post by Stynger » Tue May 12, 2009 8:11 am
Right......if you have three feet! :shock:
cuda6666
Post by cuda6666 » Tue May 12, 2009 9:27 am
At time of writing, I was not fully informed of the extent of Mark's obsession with this marque. Sure beats acquiring every Renault Dauphine found by the side of the road.
jrottn
Post by jrottn » Tue May 12, 2009 9:48 am
All foot jokes aside I have read that Braille is made by a company called Deka
The Braille is supposedly a rebadged Deka with a higher price tag (same batt.)
john bradshaw
porsche 930rs
SPA #227
cuda6666
Post by cuda6666 » Tue May 12, 2009 11:09 am
The joke's on me then, cause I just paid Jegs $150 for an 11 lb Braille :oops:
Post by breakaway500 » Tue May 12, 2009 11:54 am
I have also read that Braille batteries are reboxed Dekas,however Braille denies it.They do both use the same technology in manufacture,but according to the salesman I talked to at Braille,the rumor is totally unfounded.
I once owned a Dauphine. Did not see anything interesting about the car. :wink:
