Do assigned car numbers change?
I received a confirmation email for the NHMS1 event,and my car number was listed as 8. It was 801 last year. Is my 2009 assigned car number 8? That would be less weight on the car...
Re: Do assigned car numbers change?
I would bet you requested number "8". Numbers don't change for no reason.
Go on-line and check the information you registered with -
Mark,you are correct.I was registering for some autocross events the same day,and I use #8 for those events. I must have punched in #8 for the COM registration as well. Can I keep #8 as my number running with COM?
If that was the number in the confirmation email then that is your number.
..and I get to use it all year? I will be putting vinyl stick-on numbers next week.
How did you luck out with a one-digit number? I tried to get a 2-digit number when I first joined COM but couldn't even find one of those that wasn't taken.
ST4 Miata #62
ST4 Miata #62
I'm not sure,Dave. Might just be pure luck.No one else using it anymore is my guess. I will take it as an omen.
I once walked into the Registry to get plates for my bike,and they handed me plate number AA777 off the pile. I should never have given that plate up 30 years ago.
A new shift knob is in order
hehehe...thanks,Mick.
Watch the corner pocket....I hate bump posts!
I bid $10.00 for your # 8!
C'mon Sam,I haven't even had a chance to use it yet
I think if a number hasn't been used in two years it's up for grabs.
-Keith-
SPB116
SPB116
Is that one of those unwritten rules?
peterfontana
Is that 8 ball shift knob on a '67 Mustang?Mick wrote:A new shift knob is in order
Pete Fontana
peterjfontana@gmail.com
