Yokohomo A032-arse?
rajito
Yokohomo A032-arse?
Post by rajito » Wed Mar 18, 2009 10:38 pm
I picked up some super-duper-cheap Yokohama A032R's (S compound, yes I know, that's not optimal) early last year. They seem to be made of iron - just won't wear out. However, their grip seems to only be marginally better than the stock tires. They aren't anything like the RA1's, but it might be because I was running pressures too high/low.
Anyone have experience running these? I'm specifically interested in what you discovered about tire pressures. Did they heat up too quickly? Too slowly? Where did they seem to grip optimally? I don't have a pyrometer, but I found RA1's seem to do well when they are about 40-41 hot. I have a 350Z, which weighs about 9500lbs.
#66 SuperSlowGT
Silver 2004 Nissan 350Z
Re: Yokohomo A032-arse?
Post by breakaway500 » Wed Mar 18, 2009 11:07 pm
"I have a 350Z, which weighs about 9500lbs"
My F350 only weighs 6500lbs. You must carry a lot of ballast :lol:
I had Yoko A048's on my Atom as OEM (same S compound,I believe).I think they are similar to the AO32? I autocrossed on them a few times ,svtoa Devens style,so more like cross country style autocross.
Never liked them.Too unpredictible..no I take that back..they were predictibly crappy. Can't help with tire temps or pressures,as my car never heated them over air temperature and it weighs a lithe 1750lbs with me in it.(I ran them at 15psi mostly;tried more pressure,got worse)
When I switched to V710's (and a bit wider as well) I ran FTD, twice, against some very fast people. :shock: Same light car.No other changes.
In this case,I believe it was the tires. :wink:
Just my two cents worth... 8)
Post by chaos4NH » Wed Mar 18, 2009 11:24 pm
Raj: Buy some freakin' decent tires!
rajito
Post by rajito » Thu Mar 19, 2009 12:10 am
Well, that doesn't sound very encouraging.
chaos4NH wrote:Raj: Buy some freakin' decent tires!
AAAAAAHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have these A032R's that refuse to die, and some RA1's that seem like they have maybe 2 sessions left on them. I have a set of fresh R888's but I was saving them for WGI/MT. Well, I guess I'll have an excuse for being slow with the Yokomommas. :oops:
#66 SuperSlowGT
RyanC
Post by RyanC » Thu Mar 19, 2009 10:29 am
raj, I am running 7 year old a032rs on teh Civic, and they are so grippy still that I keep breaking axles. They don't ever die. I think I run the pressures about 40ish hot but then again I rarely check tires, nor do I have to, since I can't seem to keep the car from breaking for very long
Post by TroyV » Thu Mar 19, 2009 11:02 am
Ryan.....I think the perfect solution for you is to just drive slower. Problem solved. ;)
Post by brucesallen » Thu Mar 19, 2009 3:21 pm
A032Rs are no where near as sticky as Hoosier R6. I use A032R on the street with my lotary because they have tread. Not so good on the track.
lou m
Post by lou m » Thu Mar 19, 2009 3:31 pm
Hi Bud, You got these at the begining of last year? Did you buy them new? When did they stop making that tire anyways?
I have picked up some small (205) Hankook discontinued hard compound tires. $80. a piece. On the bright side I should still be fast on the straights. :(
Lou
Post by offcamber09 » Thu Mar 19, 2009 9:36 pm
rajito wrote:Well, that doesn't sound very encouraging.
Sell them to your parents and I'll mount them on the Hyundai
rajito
Post by rajito » Fri Mar 20, 2009 4:52 pm
offcamber09 wrote:Sell them to your parents and I'll mount them on the Hyundai
We could do that, but won't be Mustang guys be pissed off when they get beat by a Hyundai? :shock:
#66 SuperSlowGT
Post by chaos4NH » Fri Mar 20, 2009 4:58 pm
Hahahaha!! Good one Raj!
PS: are you going to let the Grocery getter beat you at NH?
Post by 6PAK72 » Fri Mar 20, 2009 6:57 pm
You guys are HARSH!!
When I was racing bikes, I started out with Bridgestones. Once I got faster, I ran Yokahama for 60 minutes at the old Briar park. They were totally, completely, ridiculously SCARY. Compound was way too hard, never ground in, the sidewalls flexed like a bungie and the tread just would not heat up.
I pulled them and bought on-site Metzlers, which I ran forever. Very predictable.
My wife's car came with Yokahama's on it. Same thing - really bad sidewall flex, poor dry traction, slippery under pressure. Swapped to Conti's and it's fine.
Must be the compound.
Post by chaos4NH » Fri Mar 20, 2009 7:10 pm
6PAK72 wrote:You guys are HARSH!!
Well maybe, but don't count out the leopard skin skivvies! Raj knows a thing or two about those!
Post by DanDarcy » Fri Mar 20, 2009 10:15 pm
Raj doesn't go diving in, he does the roto-tilling in the swamp at Lime Rock. The only STi rototiller I know of :lol:
And lets not pick on the Mustangs----- some of those Hyundais are fast ! :oops: or is it my Mustang is slow :?:
rajito
Post by rajito » Sat Mar 21, 2009 11:44 am
Haha, that was epic. "I have all wheel drive, I can just gun this thing out." So I did, and the car sank deeper. I even had mud on my roof liner.
I'll be a bystander/heckler at NHMS, but I hope to be driving at WGI and Tremblant :)
#66 SuperSlowGT
