240sx with SR20DET. What class?
0100
Post by 0100 » Fri Sep 19, 2008 6:00 pm
Hi,
Could someone tell me what class I will be in.
1989 nissan 240sx
Japan Domestic market (JDM) aka OEM NISSAN hood, headlights, fenders, bumper, and front lip spoiler
SR20DET 240sx engine STOCK
-Only thing removed is no AC, no carpet
-Stand alone ECU
- Koyo radiator
- 3" exhaust
- walbro 255 fuel pump
- hybrid intercooler
- ARC BOV
- Greddy boost controller
- Greddy air intake
- coilovers
- R33 brake conversion with s14 rear
- Circuit Sports steel braided brake lines
- nismo power brace
- Tein tension rod
- Tein tie rod and tie rod ends with ring
- Tanabe sway bar
- SPL rear upper camber arm
- JIC rear upper traction arm
- Kazama adjustable rear toe arm
- Kaaz 2-way LSD
17x8
17x9
235 40 17 DOT tires
255 40 17 DOT tires
Post by Mark Swinehart » Fri Sep 19, 2008 6:03 pm
At least Street Prepared.
What does the rule book say?
http://www.comscc.org/rules/rulebooks/rules2008-r02.pdf
0100
Post by 0100 » Fri Sep 19, 2008 6:05 pm
Well I looked and everything looked great for ST but wasn't sure with the engine. The 240sx was available with the 240sx just not this market...
[edit]Oh wait didn't think about the adjustable suspension arms, that probably bumps me to SP.
So can someone confirm I would be SPA?
Post by WillM » Fri Sep 19, 2008 6:41 pm
Car went from an inline 6 to a turbo 4. Engine swaps are not permitted in ST, so you move up to SP.
SPB is home for forced-induction 4-cyl engines.
Look through your mods and compare them to the rulebook. If all of the modifications you have are allowed in SP, than SPB.
If you have something not allowed in SP, then you move to P, and in which case the car would be classed PB.
From the description above, your fenders may conflict with 3, 6, or 9, or they may not!
On the other hand, #1 states:
1. Engine blocks may be obtained from any manufacturer.
Number of cylinders used must have been offered in that particular car.
Post by WillM » Fri Sep 19, 2008 6:48 pm
Concerning #1, at one point the COMSCC rulebook had specific wording referencing that car configurations were based on US or North American models. I cannot find that wording now, perhaps it has been removed?
If so, and if the SR20DET was available in the JDM 240sx, than I assume the engine would be allowed in SPB. If not, PB.
I guess if you wanted to split hairs, one could ask what the car was called in Japan. With that particular engine, I doubt it was called a 280-anything!
Ahhhh...rules. It is THAT time of year again.
0100
Post by 0100 » Fri Sep 19, 2008 7:11 pm
The fenders are nissan 240sx fenders just were not available from nissan in the states. Other than rolled lips they are stock OE 240sx fenders.
The car originally had a 4cyl but it was available with a 4cyl turbo (sr20det) but just not in the US. Does that matter? aren't we a world market now. :D
Damn if this is prepared that will suck. This is my daily driver, I have a baby seat in the back. :( If I put a cage in I won't have a spot for the baby and a second one is on the way.
In japan it was the same exact chassis code s13 and s14.
I am hoping to figure this out soon because I want to reg. for the NH event.
cuda6666
Post by cuda6666 » Fri Sep 19, 2008 8:32 pm
Welcome to SPB :D
0100
Post by 0100 » Sat Sep 20, 2008 8:52 am
cuda6666 wrote:Welcome to SPB :D
If I fall in SPB that would be awesome. I will sign up for the NH event right now.
Are these below suspension items legal in SPB?
- rear upper camber arm
- rear upper traction arm
- adjustable rear toe arm
I don't see suspension stuff listed in the SP rule section.
I see in ST suspension bushings are free.
Thanks guys for all the help.
0100
Post by 0100 » Sat Sep 20, 2008 9:01 am
Sorry double post
91rs13
Post by 91rs13 » Sat Sep 20, 2008 9:27 am
Another 240 in SPB --Excellent.
CA18det power in mine
DJ
# 381 T60 BMW 318
2011 Ram 1500
1972 Datsun 510
0100
Post by 0100 » Sat Sep 20, 2008 10:08 am
91rs13 wrote:Another 240 in SPB --Excellent.
Awesome, CA18's rock!
So am I good in SPB? I don't want to be illegal or anything.
Post by Mick » Sat Sep 20, 2008 11:15 am
In SP- any mods are allowed unless explicitly prohibited by the rules.
From the RuleBook:
"Street Prepared automobiles must comply with section VI, then any modifications are permitted while observing the following restrictions:"
Check section VI. You should be fine there, it's mainly general car/driver safety requirements
Then check the list of 14 *restrictions under SP-. As long as you don't violate those restrictions you should be fine.
0100
Post by 0100 » Sat Sep 20, 2008 11:57 am
Ah I see that makes sense now. Thanks so much for the clarification.
Post by WillM » Sat Sep 20, 2008 12:05 pm
Both NHMS events are filling up fast, register already!
ctkag
Post by ctkag » Sun Sep 21, 2008 9:16 pm
The intercooler & boost controller place it firmly in SPB. The suspension stuff should be fine. Come out & play with the rest of us.
-Keith-
SPB116
