A big thanks
A big thanks
I just wanted to send out a quick thank you to all COM management for putting on a great event at Mosport. A big thanks to Sam, Mark, Carl, Will, John, and to Mick for showing me the quick way around the mighty Mosport. I certainly hope we are able to get a spot their next year. I look forward to seeing you all at NHMS.
Re: A big thanks
Someone forgot to tell you where the PATH back to the paddock is eh?khissong wrote:I just wanted to send out a quick thank you to all COM management for putting on a great event at Mosport. A big thanks to Sam, Mark, Carl, Will, John, and to Mick for showing me the quick way around the mighty Mosport. I certainly hope we are able to get a spot their next year. I look forward to seeing you all at NHMS.
I hope the car did not get too damaged but the grass there is nicely cut though...
Good show Kurt! and congrats on the FTD :salute:
I thought so too, but after further inspection I found that the line that was cut had a factory hard line end on it. With no way to fix it my day was over. I'm sure Kevin from Turner will hag me out over it.Mick wrote:What happened? I thought you were all set with a new PS line, next thing I knew you were packed up.
