- Administrator
Post
by TroyV » Tue Jul 29, 2008 8:17 am
Dave_G wrote:Any time you need profanity while driving, it's not a good thing.
I guess you aren't from Boston then.... Ah.. I see your location is VT.
Post
by John F » Tue Jul 29, 2008 9:16 am
Sacre Bleu
They must use "hand signals" in Vermont!
rajito
Post
by rajito » Wed Jul 30, 2008 6:32 pm
Thank you for registering for the event!
Oh crap
#66 SuperSlowGT
Silver 2004 Nissan 350Z
Post
by StephanAlfa » Thu Jul 31, 2008 10:14 am
rajito wrote: Thank you for registering for the event!
Oh crap
You going?????????????????????????????????
Stephan de Pénasse - Classroom Instructor -
http://www.comscc.org
rajito
Post
by rajito » Thu Jul 31, 2008 11:03 am
StephanAlfa wrote:You going?????????????????????????????????
OUI!!!
Shake and bake, baby, shake and bake!
#66 SuperSlowGT
nhsilversti
Post
by nhsilversti » Thu Jul 31, 2008 5:38 pm
with raj going and me carring his tires up for him should i;
1. stack his tires on the front straight wall
2. keep his tires locked on my trailer
which one sounds better?
zip4zat
Post
by zip4zat » Thu Jul 31, 2008 5:50 pm
rajito wrote:StephanAlfa wrote:You going?????????????????????????????????
OUI!!!
OH DEER...
Post
by StephanAlfa » Fri Aug 01, 2008 4:43 am
nhsilversti wrote:with raj going and me carring his tires up for him should i;
Neither...lesson learned so no need to stack then in front of the straight wall... Locking it up? nooooooooo, he needs to go back to his "Subie groove": take tires out, bleed brakes, put tires back on...take 2 laps on the track... take tires out, bleed brakes, put tires back on... take 2 more laps... you know the drill eh?
But it will be good to have him back...that is for sure!
:thumbleft:
jrussell
Post
by jrussell » Fri Aug 01, 2008 8:06 am
With the 92db limit at Tremblant, what's the easiest way to prepare to be quieter? I've heard about steel wool, so that'll be packed and with me. How might you keep it in there though?
I *should* be fine since I have two mufflers on my car (one per outlet) but I want to be prepared in case.
BTW: It's a 1988 RX7 turbo, modified stock turbo (clipped turbine and 60-1 compressor), downpipe, most likely hollow cat, and Turbo Tuf (IIRC, it's been a loong time since I looked) cat-back.
Jason Russell
88 RX7 turbo
VEMS Engine Management
cfossum
Post
by cfossum » Fri Aug 01, 2008 8:37 am
I put one of these on the exhaust exit. I leave the flange on the car all the time, its welded on. I install the baffles at tracks with a noise limit, or else I completely remove them so it is an open hole at tracks that don't care.
http://www.supertrapp.com/product_secti ... p?CatID=27
To be honest, it sounds bad, but I don't get black flagged for noise anymore. It looks bad too, perhaps I should get a clamp-on style.
-Carl
- Moderator
Post
by chaos4NH » Fri Aug 01, 2008 8:39 am
jrussell wrote:With the 92db limit at Tremblant, what's the easiest way to prepare to be quieter? I've heard about steel wool, so that'll be packed and with me. How might you keep it in there though?
That is where the lock wire comes in. Drill a series of holes around your exhaust tip, stuff in the steel wool and run the wire between the holes to form a "net" to hold in the steel wool. It all goes back to the 1960's, believe it or not.
