L98Terror
- Fast Lapper
Post
by L98Terror » Fri Nov 09, 2007 10:39 am
John F wrote:That's funny! My wife's 03 Accord is TTE. It was a real sled when I drove it on my first outing. My Factory Five Cobra is TTS (or TTU, I didn't see where the transition was but it's one of the two)
TTS and TTU are very simple
TTS 8.7/1 weight to HP ratio or more
TTU between 8.7 to 1 & 5.5 to 1 less that 5.5 to one you're in TTR.
Once in TTS,U or R every mod is legal just bring your Dyno sheet & the weight of your car.
It even addresses the tire issue, I'd vote for following the NASA PT/TT rules for classification
L98Terror
- Fast Lapper
Post
by L98Terror » Fri Nov 09, 2007 10:44 am
Tsurara wrote:So you guys won't mind when I show up with my SCCA T2 Evo and want to run ST1
I don't see why not, My SSU car is faster than a T2 Car
- Moderator
Post
by chaos4NH » Sat Nov 10, 2007 12:28 am
L98Terror wrote:Tsurara wrote:So you guys won't mind when I show up with my SCCA T2 Evo and want to run ST1
SSU? NO mods?
L98Terror
- Fast Lapper
Post
by L98Terror » Sat Nov 10, 2007 10:25 am
chaos4NH wrote:L98Terror wrote:Tsurara wrote:So you guys won't mind when I show up with my SCCA T2 Evo and want to run ST1
SSU? NO mods?
SSU, no mods.
Currently, I have a sway bar and a Cold Air intake, but every com event I've run was with no mods, just tires & Brake pads
Tsurara
Post
by Tsurara » Sun Nov 11, 2007 10:26 pm
I would certainly hope so, don't you have a Z06? An SCCA T2 car has very little prep. If you aren't out doing much faster laps in a Corvette as compared to your average T2 car, there is something wrong with you.
Charles K.
Shawn624
Post
by Shawn624 » Tue Nov 13, 2007 2:34 pm
C4 Corvette [STGT] with suspension mods = TTC or TTD depending on the tires.
L98Terror
- Fast Lapper
Post
by L98Terror » Tue Nov 13, 2007 7:22 pm
Tsurara wrote:L98Terror wrote:Tsurara wrote:So you guys won't mind when I show up with my SCCA T2 Evo and want to run ST1
My point exactly, so why would they care if you run ST1?
Tsurara
Post
by Tsurara » Tue Nov 13, 2007 7:41 pm
The Evo isn't in SSU to begin with, you aren't making sense.
Charles K.
L98Terror
- Fast Lapper
Post
by L98Terror » Wed Nov 14, 2007 8:13 pm
Isn't ST1 a higher class than SSU
If not disregard all my comments
- Administrator
Post
by WillM » Wed Nov 14, 2007 9:03 pm
The class names in SS and how they upgrade to ST can be a little confusing. Here's how each class upgrades:
Stock --> Street Touring
SSU --> STGT
SSGT --> ST1
SSA --> ST2
SSB --> ST3
SSC --> ST4
