Would aftermarket lateral links be allowed? They allow for more fined tuned adjustablity for camber and tow in/out. It also changes the joints front regular to pillowball.X. 7. G. Camber/caster plates or eccentric bushings/bearings for the
purpose of adjusting camber/caster are allowed provided that the stock
suspension mounting points are retained and not modified. No
modifications to the stock strut towers are allowed.
Clarification for suspension changes in ST2
Ron. A
I would agree that the idea was to be able to modify the suspension without modifying the mounting points on the vehicle, this would follow along with the ability to modify the struts, springs to allow for adjustability utilizing stock mounting points.
Ron. A
I think the problem is that the rule book states that only modifications that are specifically called out are allowed. Sometimes the rulemakers (us), when writing a rule that's based on a concept (allowing camber adjustment), don't include every possible method of achieving the allowed effect. In this case, camber plates and asymetrical bushings are mentioned, but adjustable control arms are not. I'd be willing to bet that whoever wrote that rule did not specifically intend to outlaw adjustable control arms. I guess it comes down to how inflexible we want to be in the face of logic.
- Fast Lapper
Re: Clarification for suspension changes in ST2
You need to ask for a rule change.eclip5e wrote:Would aftermarket lateral links be allowed? They allow for more fined tuned adjustablity for camber and tow in/out. It also changes the joints front regular to pillowball.X. 7. G. Camber/caster plates or eccentric bushings/bearings for the
No where in the above rule does it mention modifying toe adjustment.
So, are you saying that adjustable control arms are legal if they're used only to adjust camber?
See, this is where things tend to get a little ridiculous. The intent of the current rule is clearly to allow camber adjustment devices as long as people don't go nuts and start changing pickup points.
You are absolutely right.cuda6666 wrote:You need to ask for a rule change.
Nate has been doing a great job getting the rules in line, but there is always something that comes along that doesn't fit.
I'm a huge fan of having the intent of the rule written in with the rule.
As time goes on and technology changes, the intent is about all we have to make an informed and fair decision. :dontknow:
So what is the proper way to get an ambiguity like this settled before the start of the first event? I think people building their cars for the upcoming season could benifit from this sort of clarification.
Ron. A
As I see it there are 3 options. 1) You just have to suck it up and run in the next group up where the modification is legal and request a rule modification next off-season; 2) Run the year without the mod and request a rule modification next off-season; 3) Run the year with the mod in the wrong class and risk being protested and request a rule modification next off-season.eclip5e wrote:So what is the proper way to get an ambiguity like this settled before the start of the first event? I think people building their cars for the upcoming season could benifit from this sort of clarification.
A hard deadline has to be set at some point.
Ryan Thieme
#334 ST3 Miata
#334 ST3 Miata
Option 4: Run the control arms, get protested, and then successfully argue the intent of the rule.As I see it there are 3 options. 1) You just have to suck it up and run in the next group up where the modification is legal and request a rule modification next off-season; 2) Run the year without the mod and request a rule modification next off-season; 3) Run the year with the mod in the wrong class and risk being protested and request a rule modification next off-season.
