2025 rulez
2025 rulez
Post by DanB » Thu Mar 20, 2025 4:43 pm
When they gonna be released?
Thanks!
beatus
Re: 2025 rulez
Post by beatus » Fri Mar 21, 2025 11:21 am
I think Andrew is finishing up the sheet, but the TLDR on changes:
III.A.5 (Updated allowed helmets)
Drivers and passengers must wear a Snell Foundation M, SA, EA, or FIA approved safety helmet at all times while on track. Helmets must fit properly, and the neck strap must be secured. Helmets may be modified to accept a “HANS” (or similar) component mounting as needed. Helmets must display a Snell Foundation sticker (typically inside under the liner) with “M2015”, “SA2015”, M2020” or “SA2020” or “EA2016”. COMSCC also allows the use of FIA 8860-2010, FIA 8860-2018 and FIA 8860-2018ABP rated helmets. COMSCC recommends a closed- face style helmet, however, open face, as long as it is Snell-approved, will be accepted. COM also recommends the helmet have an integral clear face shield; some tracks (New Jersey specifically) require a face shield even in closed cars. The Snell Foundation revises its standard every 5 years. COMSCC’s policy is to update this rule every 5 years to ensure helmets are no more than 10 years old. COM reserves the right to reject for use any helmet that appears damaged or otherwise unsafe
IV.J.1 (Removed multiple lines)
Window nets/arm restraints are permitted in all classes. All opencar and convertible without hardtop attached, must use arm restraints. If an Instructor is in the vehicle that has fixed windows the owner may be required to remove fixed windows if the instructor requests.
VII.D (Added i for clarification)
i. Hood may be open or closed during dyno testing unless class requires a specific position (ex: GLTC requires hood closed)
Tire Assessment
Goodyear Supercar 3R 0
Vitour P1 0
Falken RT660+ -1.5
Hoosier Track Attack -1.5
Toyo R -1.5
Maxis VR2 -2.5
Toyo RR -2.5
Conti ExtremeContact sport 02 -3.5
Michelin Pilot 4S -5
Car Assessment changes
17 Camaro ZL1 Performance assessment 12.5 Showroom assessment 99.1
17 Camaro SS 1LE Performance assessment 12.5 Showroom assessment 89.5
2024 CLA45S AMG Showroom assessment 85.6
09-11 RX8 Performance assessment 5 Showroom assessment 54.3
08 MX5 SV Showroom assessment 51.0
Brandon Ganem
#105 Mazda RX8
beatus
Re: 2025 rulez
Post by beatus » Fri Mar 21, 2025 12:04 pm
Seems like they got posted actually! https://www.comscc.org/rules/
Brandon Ganem
#105 Mazda RX8
Re: 2025 rulez
Post by DanB » Tue Mar 25, 2025 12:41 pm
Awright, thanks guyz!
