1994 Mazda Miata / 2004 Rallye 20’ Enclosed Trailer for Sale
Would like to sell both as a package but will sell the trailer separately if only the car sells
Asking $12,000 for car / $5,000 for trailer / Both for $15,000
This is a fully prepped race car. It is well known with COM for its reliability and speed. Last ran in COM class SE at upper limit of class. SCCA Logbook (ran ITA in a few races).
Factory hardtop / Full Cage by Chris Howard – SCCA inspected/approved
Ultrashield seat (17”) with head halo bolsters / Ultrashield passengers’ seat (not currently installed)
Schroth 5 point Hans harness (good through 2023)
Right and left window nets
ESS Fire system (5 liter) with Driver Front, Driver Rear, and Engine Nozzles
Hand-held extinguisher
Have title in hand
Suspension
Ohlin DFV Shocks / Springs / Front Sway Bar (Nascar type) from ISC Racing
Offset lower A arm bushings / Offset tie rods
Manual steering rack
Engine
2002 VVT Motor
144.8 HP / 126 TQ on a Dynojet224X
ECU – LinkPNP Tuned by ACE
AIM Solo2DL with hardwired power and CAN Connection to ECU for RPM, Throttle Position, Brake Pressure, CLT, IAT, FuelP
Square Top Intake manifold / Adj Fuel Pressure regulator
High flow aluminum radiator / Oil Cooler / M-Coolant re-route
High Flow aftermarket fuel rail & 265 injectors
Oil Pan baffles / Findanza Aluminum Flywheel
Shift light (adj) & Oil pressure light / Stainless fuel lines
Water Temp/Oil Pressure & Oil Temp Gauges
AEM X-series Wideband
100psi Fuel Pressure Gauge
2000psi Brake Pressure gauge
All accessory wiring through Blue Sea fuse box
Many extras
6 sets of rims and tires
Boxes of spare parts
Too much to list
[img]c:/users/bhoss/onedrive/desktop/m4.jpg[/img]
20’ Pace Trailer – enclosed
[img]c:/users/bhoss/onedrive/desktop/t1.jpg[/img]
2004 Rallye RT8520TA2
White- needs a little cleaning and TLC
Battery powered winch – 5,000lb with remote
Heavy Duty Load Distribution bars & hitch
More pics available on request.
Bill Hosselbarth
508-846-5728
bhoss47@comcast.net
FS 1994 Mazda Miata & 20 Pace Trailer
- T1.jpg (152.38 KiB) Viewed 62240 times
- m4.JPG (121.63 KiB) Viewed 62240 times
Bill Hosselbarth
COM Secretary 2011
1994 Mazda Miata
#49 PC
COM Secretary 2011
1994 Mazda Miata
#49 PC
